Think the problem is with a clogged tube running to the drain, rather than a faulty pump.
To test this theory, first turn the unit OFF & unplug it. Using an 18" long, appropriately sized, plastic Zip Tie. Carefully insert it into the drain hole tubing and continue to push it in unitil you reach a bend in the tubing. Gingerly work it past this bend until the Zip Tie bottoms out or your run out of usable Zip Tie. Then slowly pull it back out while rotating (twisting) it. This will help break up any clogs. As you reach the tip of the Zip Tie, be prepared as some water may follow. Plug the unit back in and turn the unit ON. Set the control to Pump Mode and monitor the drain for water flow.
I hope this helped you and thanks for choosing FixYa.
