Question about Braun Health & Beauty
I left this for a while and used just one side of the foil, and as I was about to buy a new one I thought I'd give this a try - a weird idea.
Try cutting a pen's spring (at the end) to a similar size to the spring and try putting that under the plastic clip. It's worked for me!
Posted on Mar 29, 2015
SOURCE: Braun shaver model 5428
I have fixed mine. the pointy end fits in a hole next the the part that actuates the long hair trimmer (on the trimmer). this points out to the side of the shaver, and the rounded end fits into a little slot on the body of the shaver, slightly lower than the track the long hair trimmer slides along, and towards the top.its fiddly getting it all back together, but its perfect now. Dead pleased.
Posted on Aug 18, 2009
SOURCE: Braun 390cc Series 3 On/Off switch appears to
Referred to Local agent - Product still under guarantee
Many thanks
Posted on Dec 30, 2009
Testimonial: "Should have realised the obvious I suppose. However, I didn't and was most grateful for the suggestion and for the speedy reply."
SOURCE: repair / replace trimmer on braun 9585 shaver
This part is only available from a Braun repair center. You can call a repair center at 847-869-7755
Posted on Sep 04, 2010
Testimonial: "Provided precisely the information I needed."
SOURCE: HOW DO YOU FIX LONG HAIR TRIMMER ON BRAUN SHAVER
Hi The trimmer is replaceable and can be purchased as an assembly. You will need a T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the old trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract. Please get back to us if you have further query or else please accept the solution.
Posted on Sep 15, 2011
SOURCE: the screen on my braun shaver has holes and needs
The correct replacements for model 8985 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Posted on Sep 21, 2011
