Question about General Electric WBSR3140GWW Top Load Washer
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
Anonymous
  • 2,341 Answers
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Posted on Aug 03, 2011
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
1helpful
Hello there and thank you for choosing fixya
This is a fairly common issue with these top loader machines
Most of the time is in the cycle timer that has gone bad and needs to be replaced.
What you are going to want to do is first try a different cycle and see if it works in any of these other cycles if not then you will know that that cycle timer is definitely bad and needs to be replaced
The timer is fairly easy to dissassemble
Your machine may have screws on the backof the machine that will allow you to remove the cover to dissassemble the timer and some of these machines have little white covers on the sides that clip on and off that need to be removed allowing you axcess to the screws behind it if so remove them and the top should be able to swing up and out of the way allowing you to get to the timer and remove the wires and screws holding it in place ok then all you have to do is to take that part and go to your nearest appliance dealer with the name and model number of the machine and get a new one ok?
please post me any comments if you need further assistance i can help
Best regards Mike
6helpful
3answers
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Clothes are still very wet after the spin cycle.
sounds like not pumping very well, try cleaning the filter/ pump
Thor laundry system won't dry clothes I have a thor no venting washer/dryer combo machine, that has been working fine for years. Suddenly it is not drying clothes and instead, clothes are soaking wet...
I am having the same problem on a WD9900A. The wash cycle works great. Spins fast and clothes are completely rung out. Dryer cycle heats up well. Fluffs and heats cloths. At some point during dry cycle water is injected on clothes and they end up sopping wet; much wetter than after wash. Filter is clear. Outlet pipe clear and functions well. Possible problem with dryer timer? Or washer timing kicking back on?
1helpful
Clothes wet after rinse cycle
lift the washer on its side and see if it has a drive blet that broken for the spin cycle.
1helpful
Spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
5helpful
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
General Electric WBSR3140GWW Top Load Washer Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
