Sony HDR-FX1 Mini DV Digital Camcorder Logo
Question about Sony HDR-FX1 Mini DV Digital Camcorder
I have a Sony HDR FX-1 and is showing this error E:61:10 Quote to repair nearly 500 British pounds Any ideas?
Posted by cris749 on
Anonymous
    Scholar:
  • 95 Answers
E:61:10 is a lens error. Unfortunately, this needs to be repaired by an experienced technician. The only thing that you can try to do yourself is try bumping the camcorder with the palm of your hand near the lens. Try it on the top, sides, and bottom of lens. Sometimes this will work temporarily. If the camcorder was hit or jostled very hard, something in the lens may have moved. The other possibility is that the lens is not making good connection to the main pcb. If the bumping works, I would think it is a connection issue.
Hope this helps.
www.austintelstarservices.com
Posted on Aug 04, 2011
  • Anonymous Apr 18, 2012
    Just had the same problem. Bumped it several times. Bumping works so far. Thank you for suggestion. Technician has charged me 130$ for repair. I'm sure - he saw your advise.
Software controlador para mi camara sony hdr-cx500
hola,
aqui tienes:
https://esupport.sony.com/US/p/model-home.pl?mdl=HDRCX500V&template_id=1®ion_id=1&tab=download#/downloadTab
saludos,
mich
Sony HDR-XR500V shows error E:62:10
Hi, This is a very well known problem that happens a lot and still today with Sony camera's and camcorders. Error messages can be found at https://www.sony.com.au/electronics/support/articles/00008857. E:62:10 is a generic error of the stabilizer. Thousands of users on the Internet have the same problem, read the website http://sony-e-62-10.atspace.cc/ or search E:62:10 on the Internet or on YouTube.
Hi there, i'm a bit of a noob when it comes to sony hardware and even to hdv video recording altogether. I have a sony hdv handycam hdr fx1e and is a great piece of equipment. however, it has recently...
Hi, I'm sorry you are having problems with your sony HDR fx-1, first thing your firewire or i-link pens is bad, it may be bent or broken this is why you can't connect to a pc , and the reboot issues may be battery problems not charging or bad cells in the battery try replacing the battery,I hope this info will help.
7helpful
3answers
Sony Camcorder HDD error
Hi There ...anyhow i have solved this problem
Regards,
Lionel
No video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
Sony HDR-HC3 Problem
humm, interesting.... You need proper service manual to open n repair this expensive camera. Service manual is available on charge basis.
Sony FX1 water damamged
Did you find a fix for your FX-1? I think mine got wet as well.
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
