Question about Nordic Track NordicTrack Treadmill, A2550
NORDIC TRACK TREADMILL EXP1000X STOOD UPRIGHT UNUSED FOR 3 YEARS. NOW SET UP, RUNS GOOD BUT THE BELT IS LOOSE . HOW DO I TIGHTEN IT?
Posted by rdesimone on
ernesto cuadra
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Have the Nordic Track ASR 630. The belt slipped off. We fixed that. Now, the display will come on but blink off and on and then go off.
Check whether the belt is over tighten or not. If so by consuming over current this problem can occur. Try to loose the belt and check whether display shows the same symptom. If not then tighten the belt without become over tighten.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Nordic Track Exercise & Fitness
Electronic control board turns on but motor doesn't run all of the time
Hi Eric, sounds like a bad connection on the motor control baord or a sensor watching the front roller or motor spin speed could be dirty. If you need further help, you can try jatinah electronics. Good Luck.
Jan 15, 2015 | Nordic Track Nordictrack Exp1000x Rear...
Belt is loose
there are adjustment bolts on the back end of the treadmill. they are on either side. start with belt running about 3mph. tighten the side where the belt is closest. about 1/4 turn. give 15-20 seconds to see adjustment . when it is centered, tighten both bolts evenly until belt is tight.
Apr 19, 2014 | Nordic Track NordicTrack A2550 PRO...
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
How do I replace a Nordic Track C2255 drive belt?
The black shavings are normal on a treadmill. It may be that you need to tighten the walking belt. Try tightening the two bolts on the rear of the machine that hold the rear roller in place. You need to tighten each of them the exact same amount or you'll throw off the alignment. Tighten them three turns of the wrist and see if that helps. If not, try three more turns. If still nothing then replace the drive belt. That can be a real undertaking and you might want to consider contacting a professional.
Jul 14, 2017 | Exercise & Fitness
Nordic track c2000 belt slips
I would try to tighten the rear roller a little and see if that helps.
1 start the treadmill and operate it at 1.5 mph then hild onto the handle bar and plant your foot against the belt at the front. If it slips tighten the roller 1/4 turn on each side. Then try the slip test again and repeat the process, do not tighten it too tight that will cause the belt to fold in teh center and be ruined. You May quite possible need a new belt. Take the belt lose and look at the underside and see if it;s glazed (shinny) or has pieces missing under the center of the belt, if so replace the belt and also clean the rollers front and rear, also flip the deck over it shoudl have a wax coating on the other side if that hasn;'t already been done.
Oct 23, 2011 | Nordic Track Exercise & Fitness
What can be done when the track slips on my treadmill?
there should be two screws one on each side of the belt in the back of the treadmill (you may need to remove the side rails (theres one on each side of the belt) to see them) those screws will tighten the belt. note: you must be carfull that the belt is tightened evenly. livestrong.com is a great website if you need help wih this. good luck!
Mar 02, 2011 | Nordic Track /proform Treadmill...
The belt is loose
there are bolts at the rear of the treadmill on each side they are usually allen keyed . tighten each of them evenly so the belt runs true do this a little at a time and test belt by stepping hard on belt . if the belt stays and the drive rollers still moves tighten some more , if it pulls your foot along then you have good tension . note not to over tighten as this will cause damage to machine good luck
Jan 27, 2011 | Nordic Track Exercise & Fitness
I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
Jan 18, 2010 | Exercise & Fitness
Have a nordic track exp 1000x treadmill and the belt is slipping
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Nov 01, 2009 | Ironman Fitness Achiever Elliptical...
Nordic Track NordicTrack Treadmill, A2550 Logo
62 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
