Question about Haier Heating & Cooling
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
Posted by guber25 on
Pete Norton
    Scholar:
  • 121 Answers
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Posted on Aug 03, 2011
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
Stopped getting cold lights are still on but i don't hear compressor run
Lori Davidson,
I understand that your refrigerator has stopped getting cold and you don't hear the compressor running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you still do not hear the compressor trying to run, I would suggest to either contact the manufacturer or your local authorized technician.
-Best Regards-
Jan 12, 2014 | Frigidaire Refrigerators
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
Hi I have a goodman MSG-18HWN1 heating and cooling mini-split unit. The unit keeps going on and off on a cycle of about 5 minutes. 5 minute, unit not started, unit starts for about 5 minutes, stops for...
Due to abnormal temp of out door.Check outdoor fan motor and compressor and also sensor.
Fan motor not working- rectify/replace fan capacitor.
Sensor defective-Replace it
Compressor high amps-Replace running capacitor.
Sensor misplaced or defective-Place correctly or replace it.
Jan 05, 2011 | Heating & Cooling
Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Jan 31, 2009 | Haier HWD1000
Compressor on Haier hmse03waww mini-frige shuts off after 10-20 minutes and is hot to the touch.
If the temperature in the refrigerator is correct then this is proper function for the compressor. It should run until the desired temperature is reached then shut off. The compressor also gets really warm. If the compressor is shutting off prior to the correct temperarure being reached then you may have a compressor problem. If the compressor is bad and our of warranty, it is time for a new refrigerator. If it is still under a warranty, call for factory service. Good luck, and I hope this helps.
Mike
Sep 29, 2008 | Haier Refrigerators
Clicking near compressor but doesnt run not even a year old haier compact mini fridge
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
Sep 13, 2008 | Haier Refrigerators
Haier dehumidifer HD656E
What you think it means is exactly what it does mean. When a running unit is shut off it should not be restarted until the system pressures have had time to balance out so the compressor can restart without difficulty.
Jun 18, 2008 | Haier 65-Pint Dehumidifier
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Heating & Cooling Logo
533 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
JOHN LAPIER
Steve Pack
Steve Pack
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
