Try to leave it without any power for a few minutes..remove the battery ..and after that plug it back and power it up ...If the code is asked just enter teh correct code and see if it works ..If it is a pin code..it may being asking for the puk code..and that one you have to get it from the provider ..but if it is just a security one ..from the phones feature it may work ...removing the battery makes it forget the date and time ..and this will make it let you insert the code again ..Usually when you insert he wrong code too many times it will be locked for a while ...
Thanks, Sir. unfortunately, it still didn't work. i forgot to note that i as well tried doing it, since that was the same thing that happened to my Nokia 1200, which i am currently using now. i haven't been able to use my Nokia 3110c for more than a month now. so bad.. :(
In this case you have to re-soft it ..or have it unlock with a professional tool or on a site using the imei number..or contact your service provider ..
here is such a site ..and it may give you a code..if you provide the imei number..
http://www.mobilecodez.com/unlocking/nok...
here you can see how to find out the emai code..after that just enter it into the case of the first link and lets hope it will work ,,Follow instructions..!
http://www.wikihow.com/Find-the-IMEI-Num...
Ok, thanks! will try this one..will update you what happens next.. :)
