Question about Hobart D300 Stand Mixer
I need a paddle and Whip attachment for the D300. What are the part numbers?
Posted by jmorgan230 on
vestxre
    New Friend:
  • Hobart Expert
  • 119 Answers
275450 "B" Flat Beater Aluminum
275451 "B" Flat Beater Stainless
275899 "D" Wire whip Stainless
Posted on Sep 13, 2011
How do I fix a wire prong on an egg beater attachment that has broke loose?
The wire whips are repairable but only by welding the whip back into place, that can be quite costly, and with new wire whips costing less than $20 that is the more economic solution.
Here is a link to the wire whips made by KitchenAid: Wire Whip MendingShed com Bowls Beaters Attachments
You will want to get your model number from the bottom of the mixer to ensure you get the correct wire whip. If you have trouble finding your model number in the chart be sure to contact us at Repairs Parts Kitchen Store MendingShed com & we will be happy to assit you.
- Colleen @ Mending Shed
Mar 08, 2015 | KitchenAid Food Mixers
Hobart Mixer D300, When mixing mashed potatoes paddle will only turn in low gear. When product is mashed with milk added it sometimes will turn in 2nd gear, but never in top. When this happens, motor is...
Sounds like the keys in the shifting sleeve may be sheared. The transmission will have to be disassembled and checked for broken parts. Check www.hobartservice.com for your local Hobart office.
Jul 07, 2011 | Hobart D300 Stand Mixer
What can you use for a hobart h600
The Hobart H600 is a 2 horse power, 60 quart mixer, it can be used for many things in the kitchen. It can be used to make about any kind of food that needs mixed, wiped or kneaded. It works well in a pizzeria for all facets of making pizza from the dough, to shredding the cheese with an attachment, to a restaurant that makes mashed potatoes and fresh bread, to a full service bakery.
However, the biggest thing that you need to know is the capacity of the machine. As overloading the machine can cause damage that may be costly and take a technician to fix. I do not know what attachments you currently have so I will go over a few of them.
The main attachments are a Wire whip, Flat beater, and Dough hook. There are three different types a "D" wire whip (has many wires and is evenly spaced) this is used to whip egg whites, whipping whip cream, etc. The "C Wing" (has six tines in it) is used for items that are heavy for the D wire whip, like whipping potatoes or icing. The last is the "I" whip is similar to the D wire whip just with less tines. The flat beater is used to mashing or mixing examples are mashed potatoes before they are whipped, cake mixes that do not require whipping, batters and icing. The Dough hook is used for kneading dough examples are pizza dough, bread dough, etc.
The biggest thing when using your mixer is to know its capacity for the material that you are mixing. All though this is one of the bigger machines it still has limits. You should refer to this the following link for the capacity of your machine:
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F-7701.pdf
There are also a few attachments that can be put on to the No. 12 attachment hub. A few of these are a vegetable slicer-grater and meat grinder.
Mar 04, 2011 | Hobart H600 Stand Mixer
I just picked up a used Hobart N-50 Mixer. Serial number is 99-700-835. It came with a whip and paddle, but the whip I had to use brute force to get off, the paddle slides on and off the shaft easily. I...
Before doing anything else, make sure the hole in the whisk is perfectly clean by taking a cotton swab dipped in isopropyl alcohol and removing any remaining residue. It does not take very much residue to make fitting difficult.
If that does not work, the hole can carefully be enlarged using a round file or sandpaper wrapped around a pencil. Do this a little bit at a time and test fitting. You will want to do the minimum necessary to get the whisk to fit.
Nov 14, 2017 | Hobart N50 Stand Mixer
Mixing blades detach while being used
type delonghi in the search bar. Pick a site and yell at them. Kidding, tell them your problem and they should work with you. Get a phone number and call them, get the salesmans name and a time frame you can expect repacements.
Oct 26, 2009 | DeLonghi DSM7 Stand Mixer
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Jul 25, 2009 | KitchenAid Food Mixers
New bowl & hook hobart d300
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Feb 25, 2009 | Hobart D300 Stand Mixer
HOBART D 300,SERIAL NR. 94.819 808, ML NR.116 12
hi i work for hobart and these part numbers dont sound right.you have to make sure you have the ml number or spec number to get the correct parts.you can call your local hobart branch and they will help you further.
Oct 21, 2007 | Hobart D300-6036 Mixer
Hobart D300 Stand Mixer Logo
198 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
