Hello download the drivers, or the manual here:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=358&CategoryID=1&DetailName=Driver&MenuID=39&LanID=0
Use windows update, for any service packs update missing.
Look also in the device manager, for drivers missing, especialy the chipset driver: VIA IDE Driver
Good luck
SOURCE: Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
SOURCE: need to add SATA controller driver
Hi voyager99,
You can download the driver, (VIA 8237 SATA/RAID driver) from PC Chips but I doupt it will help.
If your bios did no see the 250GB drive than the onboard SATA controller is defective. This can not be fixed.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=305&DetailName=Driver&MenuID=1&LanID=0
Running the SATA/RAID driver will most likely not help the bios see your drive.
Buying a PCI serial SATA controller card may allow your SATA drive run but it will run at the PCI bus speed. A decent controll card may cost as much as a new board that will run your current devices.
Mike
SOURCE: P4VM800 SATA HDD Problem Plz Help me!!!
Your P4VM800 won't detect a SATA II (3 GB/s) drive, only a SATA I (1.5 GB/s). You basically have 2 options:
1. if you have a friend or colleague with a machine that supports SATA II, install the disk in that machine and us the manufacturer's utility to set the SATA to 1.5 GB/s (Seagate/Maxtor disks, but only these do have a jumper to do the job but SATA is in other respects jumperless). Then you can reinstall the disk in your machine.
2. Buy a host adapter card for SATA II and install it in a free slot in your machine - but may be better to put the money towards a new motherboard.
SOURCE: brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
