SOURCE: suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
The bearing and seal seal kit comes as one(two bearings) cost around 20-30 GBP. take top of machine and look to see if the plastic outer drum is joined in the middle with screws. If it is the whole machine has to be stripped. If not you can gain acces by removing the front panel of the machine. To have an engineer do this work it would cost between 100-130 GBP. Its quite a big Job.
SOURCE: drum bearings replacement
go to this site...
www.Howthingswork.com
it is amazing what you can find there
SOURCE: Worn bearing on Dyson CR01 drum
its all down to the water seal in the bearing housing if this is gone the machine is scrap as you can not get them.. The bearings can be got from any good auto (car) bearing supplyers.they need to patten mach them for size.this is the main steel bearing that the hole drum spins on there is also a small brass bearing thats part of the two way drive system but this needs a puller to get to it..bottem line is if the drum does not turn both ways in side its scrap..if you take the back off and theres rusty/gressey water dripping off the back off the drum..scrap it
SOURCE: bosch wfmc2100uc is growling and squealing
there is a bearing on the belt pully that is in the back of your tub that is probably bad. if you remove the back cover look for black greese splatter (bad sign). that is abpout a 3 hour job for an experienced Bosch technition and very expencive. to answer your question call a Bosch repairman in your area and ask for a parts breakdown of that area, they should help you out.
