Question about Xerox Phaser 8560MFP Laser Printer
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Posted by alain293 on
guilopmar
  • 304 Answers
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
This must be performed following an ink loader replacement.
2. Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
No)Replace the Ink Loader
Posted on Aug 03, 2011
No display
You probably have to replace the display. It is a common problem.
Oct 19, 2014 | Xerox Phaser 8560MFP/SN - 30 PPM...
I need a diagram of a Xerox Phaser 8560 MFP?
Do you need a parts diagram? For which section or part are you looking for?
Apr 25, 2014 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 MPS System Error Press (?) 09,038.46:1252 Help Me Please... [email protected] [email protected]
The ink-loader is defective and probably needs to be replaced.
The MFP ink-loader is unique, so you must buy PN 848K06380
Whit
Item, Inc.
Sep 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Trying to remove the printhead for replacement, but the only parts manual I have is for the Phaser 8560 printer, not the 8560 MFP unit. So none of the drawings quite match.
You have to remove the scanner assembly first. Then, to remove the side covers, you have to jab a screwdriver in the right place to release the side cover. It's a bear the first time even with a good drawing.
Jun 11, 2009 | Xerox Phaser 8560MFP Laser Printer
Code 39,003.40:53889
What you can try is shut down the Machine and unplug the powercord and unscrew the cable next to the powercord.
It's from the scanner.
after that reconnect both cable's and turn it back on.
and it should be fixed
Mar 12, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 mfp code error
Thanks for your assistance, but I found out the machine is still under warrenty and is scheduled to be fixed.
LeRoy
Jul 11, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
229 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
