Question about Hardware & Accessories
I need a set of trippers for a Paragon timer Model number 4001-00. Where can I get them. Thank you. My name is Jim Vivone
Posted by truman8830 on
Jim Moody
    New Friend:
    Problem Solver:
  • 9 Answers
Anonymous
Google search for X2772 tripper and some places may still have them.
Paragon is no longer making timers and parts except defrost timers.
Paragon 4001-00 120Volt timer uses X2772 tripper:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Paragon 4001-00 crossover to Intermatic is T101 120Volt timer.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring:
Paragon 4001-00 has terminals 1 2 3
T101 has terminals A 1 2
Paragon terminal 1 connects to Intermatic terminal 1
Paragon terminal 2 connects to Intermatic terminal 2
Paragon terminal 3 connects to Intermatic terminal A
Posted on Aug 03, 2011
I need the on tripper for timer 4001-00
Google search: X2772 tripper
Thank you for including model number.
Paragon is no longer making 4000 series timer or the X2272 tripper.
Some places might still carry the tripper.
Resources:
Replacement timer for 4001-00 is Intermatic T101 timer:
Crossover wiring from 4001-00 to T101:
Resource:
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
What is name of srew on timer dial that trip switch .
It's called a tripper.
Question posted under Paragon 4000 series timer that uses X2772 tripper.
Paragon is no longer making that timer or tripper.
If different timer is needed, use Intermatic crossover to match timer number:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Sep 01, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Moved time pointer on pool timer to set time than read instructions moved pointer back to original spot now timer does not click on or off when it passes pins
Timer brand and model number are not shown.
Brand and model appear on inside of timer door.
Moving stationary pointer will not affect on-off operation of timer. The pointer is just reference for setting current time.
Worn trippers can cause problem.
Trippers are softer metal and designed to wear down so timer mechanism lasts for decades.
Intermatic pool timers use set of 156T1978A trippers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Tork timers use P47 tripper on 24-hour clock dial
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
Paragon 4000 series uses X2772 tripper. Paragon timers are discontinued and trippers hard to find.
Open following links for different timers:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Tork-timers-and-manuals.html
Aug 01, 2011 | Hardware & Accessories
We have a Paragon Time, Model #4001-00, TD-1744-00 at our softball field to control bathroom lights. The 2 ears or shut-off and turn-on devices were lost during some electrical work and we cannot find...
1) Open following link to identify timer and download manual
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
2) 4001-00 series is heavy duty Nema 1 indoor 40 amp 120Volt mechanical timer with analog dial.
I don't recognize TD-1744-00
I'm not sure what you mean by 'ears'
3) Maybe you mean X2772 trippers?
Trippers are set on dial to control on-off switching.
If trippers are missing, Google search for X2772 tripper and some places still sell them.
4) If another part is missing, you might not be able to find that part, but you can photograph the problem and add a comment to this thread and include photograph so I can look at it.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
5) if you have to replace timer, some places still sell Paragon 4001-00, or replacement is Intermatic T101 or T103 timer
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 01, 2011 | Paragon Hardware & Accessories
Where can I find the timer triper set for a paragon 4001-0g
1) Paragon 4000 series uses X2772 tripper.
2) Internet search for tripper reveals some sources selling set of trippers for $50.
Paragon is no longer making timers or parts, except for defrost series timers.
4000 series is not a defrost timer, which explains high price for trippers.
Some sources might still have X2772 tripper at lower price.
3) Other companies are still manufacturing some Paragon timers for niche sales.
Certainly the Paragon line is still active although names and numbers will probably change over next few years.
4) I cannot specifically identify 4001-0g, and the 'g' suffix does not show in sell sheet
5) Replacement timer for 4001-00 is Intermatic T101
6) New T101 from Amazon is $45.00 with free shipping
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
Add a comment for more free help.
Mar 23, 2011 | Paragon Hardware & Accessories
Lost pcs.that turn on and off the little silver clips that screw onto the disc.where can i find replacements? the ones i found at the hardware store dont match tab is in a diffrent location. its the older...
If I understand correctly, you need tripper pins for a Paragon timer
http://www.paragontimecontrols.com/parts_accessories.htm
At page bottom is a chart with model number and the tripper required
The two links above help you identify your timer model and identify the tripper.
After identifying tripper number, you have to do a google search for that tripper number
So, if you need more help, please answer back and we'll find the right timer and pin
If you have Intermatic timer, then you can buy pins at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Oct 21, 2010 | Paragon Hardware & Accessories
We have an AMF Paragon 4001 timer for the light outside our building. The light goes on lately at the wrong time. We want it to be on at 7:00pm and off and 5:00am but it goes on at 12:00 at noon.
To set paragon timer: Pull large round dial straight out towards you, then rotate dial until correct time is lined up with stationary 'pointer' on front of dial
Sep 08, 2010 | Paragon 4001-0G Defrost Timer
I have a Paragon 7008-00 timer that has no trippers
Yes, they can be installed by a layman. The problem is finding a place to buy them.
You should be able to find and buy them from a number of sources on the Internet. Just do a Google search on that timer, or go to the Paragon website to buy, or at least get the part number to use in a Google search. Part number is X4299.
FYI - Most people use a different timer than the one you mention for this purpose.
Dec 14, 2009 | Paragon Indoor Electromechanical Timer...
Hardware & Accessories Logo
795 people viewed this question
Top Hardware & Accessories Experts
Tom Chichester
ray gallant
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
