There are several touch pad buttons that could activate the Child Lock feature on a Kitchenaid dishwasher. To toggle off the lock, try pressing and holding the 4-hour delay dry or the energy saver dry key pads for 4+ seconds. The Energy Saver Dry is used for the Child Lock on the Kitchenaid KUDS25SHWH1. This manual is here: https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L9050329.pdf . The 4-hour delay or Control Lock options are listed in this manual: https://www.kitchenaid.com/content/dam/global/documents/201605/owners-manual-W10596243-RevD.pdf . If neither of these steps work, you may have a problem with the keypad, the wiring between the keypad and the control board or the control board itself.
Please add a comment with the model of the dishwasher if you'd like me to try and find the parts list/diagram. If the machine is under warranty, you may want to contact Kitchenaid.
Getting it out of child lock can be difficult but make sure you watch the light on the front panel it will go right back to lock if your not careful.I had to try several times at first I thought it would need a doctor.. but with patience it should work and unlock with the 4 second hold.. power down does not reset unless you wait 30 minutes or longer.. hope this helps
Well you can please follow the below steps - 1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model. 2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled. 3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
It would have helped if you provide the Dishwasher model.
HOwever, I am assuming you have the power connected and inlet water is turned on.
It is likely the child control button might be enabled. CHeck dishwasher manual to show how to disable child lock.
If this is not the problem, then assuming your dishwasher has this feature, try to hard reset the dishwasher to factory setting. This is usually done by pressing 2 buttons (depending on dishwasher) together for a specific time. Or in some cases the mains power is turned off and on within a specific time.
Please post a comment to indicate your observations and model no. Please do not rate this solution until I have got some more details of your dishwasher problem.
