JACK UP CAR SUPPORT THE CAR WITH JACK STANDS AS YOU WILL NEED THIS LATTER THEN REMOVE THE TIRE TAKE BRAKE CALIPER OFF THEN TAKE ROTOR
OFF THEN REMOVE THE SCREWS ON THE BACK OF THE WHEEL BEARING THEN WITH A CHISEL START BANDING ON IT AT ONE CORNOR TILL IT BEGINS TO MOVE THEN DO THE OTHER CORNER THEN THE BEARING WILL COME OUT THEN TAKE SOME CLOTH SAND PAPER AND CLEAN THE OPENING AS BEST YOU CAN( THEIR WILL BE RUST ON THE METAL)THEN PUSH THE NEW BEARING IN ONLY ENOGH FOR THE BOLTS TO START GRABBING THEN ONCE ALL BOLTS ARE STARTED START TIGHTENING THEM DOWN 1 FULL TURN PER SCREW EACH TILL THAY ARE ALL TIGHT THEN PUT EVERY THING BACK TOGETHER. NOW THE NEW BEAR MAY SQEAL FOR THE FIRST DAY OR TWO TILL THE GREASE INSIFDE THE BEARING GETS FULL DISTIBUTED ON THE BEARINGS. LET ME KNOW IF THISW HELPS [email protected]
