Hello
The fault symptom as you indicates is with lamp problem itsef. If you are aware in electronic equipment repair, you can do it by yoursef. Replacing the lamp is a crucial work indeed. If you have confidence to do this work, chenge it by yoursef. Lamp can be detached from the TV, and can be replaced. There is a number for lamp and must be replaced with same type and number. There is a chance to break the lamp while taking in out from the device and to insert a new one. So if you are not so experienced, let it get replaced by any well experienced service technician I advice. OK.
By any way, replace the lamp with original number. It is a high pressure mercury discharge type lamp. The lamp part number is [TY-LA2004]. To purchase a replacement, call the
Panasonic accessory department, toll free at:
1-800-332-5368. To see how the lamp can be replaced, this video will help you a lot.
Thanks, that is what I plan to do. Already removed the old lamp module from the TV. Saw some small shards of something in the bottom of bulb. Plan to get s price quote on module replacement from tv repair shop it order replacement online.
