2003 Suzuki Grand Vitara Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 suzuki esteem glx 1.8 need diagram and instructions for replacing serpentine belt.
Willie Keisser
Level 3:
Master:
  • Master 457 Answers
  • Posted on Aug 03, 2011
Willie Keisser
Master
Level 3:
Master:
Answers
457
Questions
0
Helped
125146
Points
1387
THE DIAGRAM IS ON THE HHOD ON UNDERSIDE OR ACCROSS THE FRONT TOP OF RADIATOR. THEIR IS A BELT TENSONER THAT LOOKS LIKE A ARM COMEING DOWN WITH A PULLY ON IT. PUT A SOCKET ON THE PULLY AND EITHER PUSH FORWAR OR PULL BACK AND IT WILL MOVE TO ALLOW THE NEW BELT TO GO ON. WHEN YOU LET GO IT KEEPS TENSON ON THE BELT.
2answers
I need to know where a cam shaft sensor goes in a 1999 Suzuki Esteem 1. 8 4 door stick show me diagrams
not true, Huseyin.! at all.
OP: (original poster)
J18 engine. FWD. application. USA setup
with COP coils x4 (DIS ignition?)
our Esteems started in 1999....
other countries have them too, but use totally different spark (distributor) and Im not answering for THAT, only USA EPA spec. engines.
some othere countries, has a Mazda. 1.8L BP.
answering for J18 only.
the J18 is an understoked, J20. (early engine)
good to know for parts swaps !
OP backup and read your first post.on same topic.
the answer is there, too.
facing engine, crank pulley on left
see that head, see the front cam,
this cam has the CMP drive (left side,) or right facing engine) the cam drives it directly.
so... is just there.
why? not scan the PCM and see if you have P0340 errors = CMP misfiring..... (even 1 in 10)
and the prev. post has the real diagram....
cmp mount is here.
http://www.fixkick.com/engine/20Liter/html/image_21.html
see it?
the part is also shown at the online suzuki parts pages.
Scan it, get this ???????
25724232-hn0kodpeugglx5i5nhvgnujg-5-1.jpgas you cans see, the FSM is full of CMP facts,
factory service manual. NO photos?, BAH!
1helpful
Serpentine belt diagram for 2007 suzuki xl7
http://www.suzuki-forums.com/1g-1999-2005-vitara-grand-vitara/37520-serpentine-belt-other-belt-tensioner-replacement.html
1helpful
How To Replace The Serpentine Belt on Suzuki Esteem?
wow, no year stated !
there are 2 engines. the 1.6L G16B SOHC is yours?. and has a belt , the 1.8L is a chain, so what engine does it have? the 1.8L is DOHC, chain motor.
the G16, is used in the sidekick (and geo trackers)
here is the side kick page, us it and the esteem G16b book and you will see hints.
the only hard part is the Esteem makes repairs very hard. FWD.
http://www.fixkick.com/t-belt/16-fast-belt-install.html
use a Gates belt , not china clone no name and win.
the above his lots of noob hints, or may tell you, let the pro do it.
1helpful
How to replace a serpentine belt on 1998 jeep wrangler
Should be the pulley underneath the power steering pulley. Loosen the nut, then back the bolt down the loosen the belt, tighten the bolt to tighten belt.
5helpful
2answers
2001 suzuki serpentine belt diagram on 1.8 engine
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/2001/make/suzuki/model/esteem/2001_suzuki_esteem_drive_belt_routing_diagram.htm
Serpentine belt
Make a trip to your local Autozone parts store. They will gladly print out that diagram for you at no charge.
Thank you for adding your comment
Bill, ASE Master Technician.
Drive belt/ serpentine belt replacement, 1.8 liter, Esteem 2000?
If you run the engine at idle you will see the tensioner pulley move, the movement will be slight but steady.
2helpful
2answers
Alternator belt replacement
you have to loosen the motor support and jack that side of the motor up
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
