I also found a link to the manual for the AP148DS here: http://homeappliance.manualsonline.com/ex/thread/view/idThread/295978 . However, you need to be a registered user (free registration) to access the link. Click on the Get This Manual button and the registration/login will pop up. This may be a similar enough manual to help you use the A/C.
Good day, In the freezer compartment, after you remove the rear panel, you will see the cooling (evaporator) coil. There is an aluminum pan directly below the coil. The drain hole would be obvious unless it is iced over, in which case you would need to melt the ice out.
It is connected to the drain hose which you can see by removing the back bottom cover of the machine that houses the compressor. If open and working properly, the hose carries the water to the drain pan which allowsit to evaporate.
If the freezer has an ice maker, it will have to be removed first. In addition any support brackets if they prevent the removal of the rear panel.
Self evaporating simply means there is a drain pan with a heater device installed that will evaporate and condensate that drains from the unit into the pan.
You do not need the external drain pan unless the unit makes more water than the drain pan and drain pan heater can handle.
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Don't bother. Couldn't find it either. If you have a Stop error try draining the water from the pan. its not sealed so be careful if you pick it up. I had that problem Amana was NO help. Started right back up!
Empty the water pan. It not sealed so dont slosh it around. Mine did the same thing. Amana rep was an ***. Wouldn't give me an inkling of what to do. So i started to fiddle around. There was a lot of water in it Be careful. I brought mine to the tub and drained it for close to 2 min. Started right back up!
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
