Most of the time, when BOTH the oven bake and broil elements don't work, it is usually caused by an open thermal circuit breaker or fuse. When did your oven stop working? After a self-clean? This is the most common cause of one of these thermal fuses opening. Usually this device is located on the back of the oven. A few of them are manually-resettable; but most of them are one-shot thermal cut-out devices (thermal fuses) which have to be replaced once they have been triggered.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
Kenmore stove ,oven not working.I cannot find thermal fuse on back panel.Wojld it be inside control panel and how to access it.Thanks William model 645131
If your Kenmore electric range model 790.9232 oven is not working and the control panel is blank, there are a few potential causes for this issue:
Faulty control board: The control board manages the oven's functions and if it is faulty, the oven may not work and the control panel may be blank.
Power supply issue: There may be a problem with the power supply to the oven such as a blown fuse or tripped circuit breaker.
Wiring issue: A wiring problem such as a broken wire or loose connection may be preventing power from reaching the oven.
Thermal fuse: The thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse has tripped, the oven will not work and the control panel will be blank.
It's best to have a professional technician diagnose the issue. They will be able to identify the specific cause of the problem and make the necessary repairs. It's also important to check the owner's manual for troubleshooting options or error codes that might be displayed on the control panel.
It is also important to check if the range is properly plugged in, or if the outlet is working properly. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18-6--/Kenmore-Oven-Won-T-Turn-On
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
