Remove the blades and punch out the shaft. Clean it all and then reassemble it with lots of water pump grease (it's waterproof). Seizing happens because liquid goes down between the shaft and housing and sets.
Or
You can replace the blade assembly. The link below shows unavailable, but it shows the screw cap.
Cuisinart11 cups (total processed weight varies by food) ... PowerPrep® metal dough blade, metal ... bowl at the top with ... filled out. WHEN. REMOVING BLADE: CAREFULLY REMOVE. THE METAL BLADE BY .... (If machine does not ... not put base in water or... These features, plus the .... have passed into the ... food from leaking.
Cuisinartmatching outline O on top of .... base in water or other liquid. General ... does not fit fully in the outlet, ... as you would sharp knives, out of ... 11. KNEADING YEAST DOUGH WITH DOUGH BLADE. 12. KNEADING BREAD DOUGH ... loodfrom leaking...... uid onto dough as it passes under ..... Fill the feed tube wilh the pieces,.
sounds like the bearing assembly went, right where the motor connects to the blade, you can get a replacement base from them, have to find the model number and go to their website. doubt you burnt it up. cuisinarts supposedly are commercial quality.
Sounds like the teeth are stripped underneath the blade. Make sure it's put together correctly before you do anything else. Download Cuisinart CBT 500 Manual
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Your model is a Costco version of the CBT-500FP - only a few minor differences - here is the recipe/instruction book for that model, which should get you going: http://www.cuisinart.com/share/man/425_man.pdf
Remove blender attachment completely, turn machine on and see if it will spin with all attachments removed - if it spins, then replace the blade assembly - parts available from Cuisinart. If it doesn't spin, send to Cuisinart for repair (call first).
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
