Question about Danby Freezers
I have poked a hole in my freezer unit while defrosting and the gas escaped. Can the hole be repaired and the gas replaced?
Posted by thomasc1950 on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Yes it can, but you are going to need special equipment. Such as a vacuum pump to remove the air, Touch to repair the hole or replace the evaporator that you poked the hole in. Along with a set of gauges and refrigerant.
This is not a job for the average DIY'er and even as a pro I only repair sealed systems (leaks, compressor, etc..) if they are under warranty because it's a time consuming and costly job other wise.
If the refrigerator has any age on it then you may want to start shopping around for a new one.
Posted on Aug 03, 2011
Like many folks before, I have punctured my freezer while defrosting it with a knife (yes, stupid thing to do). The coolant is hissing out of the freezer right now. The question is: will the fridge still...
Once a hole allows freon to escape, it's usually best to replace the product, as moisture will enter the sealed system and contaminate everything.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 10, 2017 | LEC Freezers
I have this majic chef freezer about 7 cubic ft. 3 years old turned it off to defrost and when turning it back on it won't get cold?? Compresser is hot so I believe it is working and lights on in front...
I'd let it dry out totally then try it again, some of the electronics may have gotten wet when you defrosted it. Give it a week somewhere warm and dry like a garage. If you didn't attack built up ice in the freezer with a knife while defrosting it it should work after it dries out. Most people end up killing freezers by accidently poking holes in the evap coil while trying to remove built up ice.
Aug 14, 2011 | Magic Chef Chest Freezer MCCF5WBX
Admiral 2!ADW (2001): ice on the floor of the freezer compartment and floor wet around left front of cabinet
The discharge tube of the unit is blocked (defost the unit totally before doing this process), locate where the water discharge is located inside the freezer,,,usually lower rear of the cab, you will see a run-off chanel to a central point, it may have a small filter 5 - 10 mm hole. Remove the filter and use a piece of edge trimmer cord (500mm long) poke it down the hole till you see it appear in the evap tray located over the compressor located in the rear lower external of the unit, you will need 2 people to complete this process, 1 inside the unit poking and one looking at the collection tray over or by the compressor. you may need to thrust the cord down a couple of times to clear the blockage but it will work a treat...Regards Russ
Dont forget to vote.....my time was for free....thankyou
Mar 08, 2011 | Maytag Freezers
My upright freezer has collected water in the bottom and froze. What caused this and how to fix it?
Defrost cycle causes it. It comes from humidity in the air. You might have a blocked drain line. Try defrosting the unit for 24 hours and clearing the blockage in the back. There should be a half inch hole for water to drain out.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 23, 2011 | Whirlpool Upright Freezer EV201NZR
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Sep 30, 2010 | Haier 4.5 cu. ft. / 127 liter Chest...
Gibson Upright Freezer
Is it a self defrosting? Or not? And how did you defrost it?If you scraped and chipped the ice away, you may have poked a hole in the evaporator and the refrigerant (freon) leaked out.
Jan 03, 2010 | Frigidaire Freezers
Freezer ok, fridge not cold
Often you can unplug it overnight and it'll melt out, correcting the problem for some time.  The electric element might be burned out, although I'd suspect the defrost timer.  It's usually located behind the unit, near the bottom.  Often all you will see is a 3/4" hole in the back plate with a flat screwdriver slot.  Turn it (only turns one direction) with a flat screwdriver, and all will work fine for some time (usually).  If not, standard procedure is to replace the defrost timer assembly, as the clock motor has likely gummed up.  Maybe available at http://www.repairclinic.com, or a local appliance repair shop.  They're often generic, as in not specialty oem specific.
Jul 16, 2009 | Freezers
Punctured the inside wall of the freezer - gas has escaped
you're all done buddy. sorry to say i have never seen in 21 years of doing ac and ref work anyone that could weld aluminum saturated with oil . an airtight hermetic seal is mandatory, and with a hole punched its new unit time. sorry
Nov 13, 2008 | Freezers
Hole in freezer
Time to get a new one. I take it you defrosted using a sharp object. Not the thing to do. Defrosting can be done with a simple device such as a hair dryer and do the system no harm.
Jun 16, 2008 | Freezers
Freezers Logo
237 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
ADMIN Canada
ADMIN Canada
Are you a Danby Freezer Expert? Answer questions, earn points and help others
