SOURCE: Charger for Mintek portable dvd player 1810
eBay has a few charges for your portable dvd player.
SOURCE: cannot disconnect battery from "mintek
I PUSHED THE RELEASE BUTTON ON THE BACK OF DA UNIT AND THE BATTERIE SLID OFF....IM SORRY WHEN A COIMPANY GOES OUT OF BUSINESS I DONT FEEL I SHOULD HAVE TO PAY FOR ADVICE....I UNDERSTAND CAPITOL GAIN FOR "YOUR EXPERTS" BUT THAT DOESNT MAKE IT RIGHT.....IT COST ME MOR FOR ADVICE THAN I PAID FOR THE UNIT......AND THAT I CANNOT JUSTIFY....THXS FOR NOTHING
SOURCE: i have a mintek DVD
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
