We are having same type of problem - sending print jobs from two separate Fiery XF systems that are verified working AOK with other printers. My guess is a service call is required to replace the LAN card or logic board. How did you resolve this?
Most likely this is a problem with windows not the printer
usually the spooler service in one of the windows machine that connects to the printer is stalled or overloaded.
your not likely going to be able to fix this yourself but if i new what version of windows you have i could help
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
SOURCE: Epson Stylus Pro 9880 Does Not Print
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: epson printer won't print
That sounds a lot like the print spooler has suffered some kind of problem...
Try the following:
Tip: This is the same thing as going to Control Panel > Adminstrative Tools > Services
From here you:
This will restart the print spooler.
If the spooler is the problem you should be able to send a print job to the printer and it should now start printing.
If not then the chances are this is either a port misconfiguration or a driver error in which case you should try:
If the port was misconfigured this SHOULD solve the issue but there's no guarantees... If you're still having issues, post again and we'll go from there..
Hope this helps.
Martin
SOURCE: epson stylus d92 won't show ink levels
hello
Download the the driver again and reinstall it.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVGcisk9ncQeIBmTUU002FxOg74o84TjGD6F5MAU003D&tc=6
SOURCE: epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
We resolved this issue by restoring the NV RAM from a previous backup.
