Question about Samsung ES28 Digital Camera
1. Press down + shutter + power (firmware version is displayed) 2. Press menu - 3 seconds 3. Appear Ptp Adj Enabled 4. Press the left
Posted on Dec 22, 2013
SOURCE: canon powershot SD750
Hi
Very odd... sounds like the camera is just in a power save mode and should still work.
Try pressing the "Disp" button, does the LCD turn on? Press it again after a second.. does it all now turn off? Press it once more and the LCD should turn on again.
If this doesn't work, then one of two things is most likely wrong. Your CCD is bad, or the aperture in the lens is stuck closed. Either problem requires the lens to be replaced, and no camera shop or store will do it for less than $150-200.
If the aperture is stuck no light is getting in the lens so there is nothing for the camera to record, but you can still see the menus and old pictures just fine. If the CCD is bad, the light is getting in but the camera can't convert it to a digital signal that it can record.. so once again you can still see the menus and old pictures but you can't take any new ones.
I've been building an AFFORDABLE digital camera repair business (Google Darntoothysam) for several years now, I'm just trying to reach people I can help. We offer a lens replacement package for about $70 in our store, you won't find a price like that anywhere else!
If you can use us, please let us know. Even if you don't use our services feel free to ask questions if needed.
Good luck from Darntoothysam com
Thomas
Posted on Oct 13, 2008
SOURCE: Our Olympus 7010 has gotten the lens stuck out,
Fixing a Lens Error on a Digital Camera This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move. The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason. A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth. Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods. The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired: Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on. Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time. Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera. Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one). Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes. Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens. Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 16, 2010
Testimonial: "Fix#7 worked. Thanks so much!"
SOURCE: Have got new ES28 Samsung
Move the slide switch on the side of the card.
Posted on Sep 12, 2011
SOURCE: looking for manual - samsung digital camera ES28
The user manual is available for download in a variety of languages here: (click here)
Posted on Dec 08, 2011
SOURCE: Samsung ES28 Digital Camera - no connection with PC via USB
have you tried connecting other memory drives with your computer? maybe there is a problem with your computer's hard drive. If the other devices can be connected, then check your cord for an damages and get a new one perhaps
Posted on Apr 03, 2012
Jul 09, 2015 | Samsung ES28 Digital Camera
Oct 28, 2013 | Samsung ES28 Digital Camera
Jan 07, 2013 | Samsung ES28 Digital Camera
Apr 03, 2012 | Samsung Cameras
Sep 11, 2011 | Samsung ES28 Digital Camera
Jul 05, 2011 | Samsung ES28 Digital Camera
May 11, 2011 | Samsung ES28 Digital Camera
Mar 14, 2011 | Samsung ES28 Digital Camera
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Mar 26, 2007 | Samsung Digimax L60 Digital Camera
Feb 08, 2014 | Samsung ES28 Digital Camera
Dec 11, 2013 | Samsung ES28 Digital Camera
691 people viewed this question
Thank you man, is good answer.....
