The red flashing indicates a low (or check) battery. The instructions on
page 4 in the link below for the Plantronics Backbeat 903/906 will
show you how to charge it up. On page 8 you'll see how to power down and
then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Good luck from Headsets Direct!
To pair
the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing"
button until the LED indicator flashes blue and red. This will put the
903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also
require you to accept the connection. Headset is paired when LED flashes
blue.)
On the EVO 4G:
Turn
the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks,
Bluetooth.
Pair
the EVO 4G by going to the Home screen, press Menu, Settings, Wireless &
Networks, Bluetooth Settings, Scan for Devices.
Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
