SOURCE: Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
not unless you make it yourself ..replacement handle is just like the 1 that broke
SOURCE: Replacement of Door handle
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
SOURCE: Microwave Oven Door Handle Replacement
You shoul take off the hole door, use something like a flat screw driver and wedge the plate off.
some of the mics got tamper holes where it hooks in.
Hope it works...
SOURCE: whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left
side of the Central Control Unit and release it from the wiring harness
brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release
tab at the back of the drawer and pulling it completely out of the
washer.
Once the drawer is removed, remove the screw in the recessed hole next
to the drawer opening. Release the tab securing the right side of the
console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot
in the bottom center of the console. Push the console up to release
center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the
Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Hello
& Welcome to FixYa
Please
review this video if you want to replace it yourself:
Please
get back to me if you have any other questions.
Kevin
