TruTech  Clock Radio Logo
Posted on Aug 02, 2011
I need the manual. I don't remember how to set the alarm. Is it #1 or #2?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Sep 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
954
Points
How to set alarm on samsung tracfone
If it's the T105G (same one I have), here's how:
  1. Select "Menu"
  2. Select "Tools"
  3. Select "Alarms"
  4. Make sure "Wake-Up Alarm" (1) is highlighted and press "Options"
  5. Press "Select"
  6. Press the ">" key to turn alarm on
  7. Pres the "v" key to highlight "Alarm Time"
  8. Enter the alarm time with the keypad
  9. Press "Save"
I don't know how many other Samsung models TracFone sells. If yours isn't the same one and doesn't work the same way, you can check TracFone's website for details.
1helpful
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Don't know how to set alarm or time
Please download the user's manual from here:
http://www.nodevice.com/user_manual/download_346371.html
Then read pages 14-15 for setting the time and pages 16-18 for setting the alarms. This guide is detailed and good enough.
Thanks.
gylacz
Hi I would like to change the Flexible Buttons on our Panosonic KX-DT333 can you please help? Thanks
To what? There's a complete table in the Operations Manual (OM) or can you remember 0, 1 and 2? 0 assigns single lines....don't touch them. 1 plus ext assigns intercom numbers, and 2+access code and number is used to set personal speed dials (you also have 30 under the touch pad). Other commands set up Transfer to VM, VM record, CID display, Headset mode, etc. etc.
If you don't have a copy of the OM, here's one. Please rate this solution because as soon as you do, or after a short time, this manual will be gone. http://public.carl.airpost.net/misc/200_TDA_OM_10-11.pdf
Carl
I have misplace my manual and I was wondering how to turn off the hourly chime. ms 1000
Get to the alarm screen by pressing the mode button as many times as you need to. At the alarm screen, a short press on the lap-reset button toggles the chime on and off. Don't press and hold the lap-reset button: that toggles between alarm 1 and alarm 2.
My harmony 600 wont control my Bell 9241 PVR
Your 9241 needs to be set to remote codes set #1 in order to work. The Harmony uses code set #1. You can do this by following the manual in the guide which comes with the unit. I don't remember exactly how to do it but it is in the manual. Once you change the remote code set to #1, the Harmony should work. I did this with a Harmony 300 and it worked flawlessly. QuintusPRE.
3helpful
NEED AQUALITE MANUAL - CAN'T SET TIME
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press any button on the watch.
Apr 09, 2010 • Watches
8helpful
3answers
Ge 7-4901a
Push the SET WAKE/TIME button on the far right of all the buttons - it's the button closest to the CD player. Push it until the 1 or 2 show up on the display - whichever one you want to use. The push the CD player's forward button - the one with the two right-facing arrows - until the time you want to wake up shows up in the display. That's it. To turn the alarm off, push the WAKE CANCEL button, below the set wake/time button, the push the 1 or 2 button, depending on which alarm you want to turn off. The display will show OFF in the alarm you chose.
Top TruTech Audio Players & Recorders Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a TruTech Audio Player and Recorder Expert? Answer questions, earn points and help others
