Some remotes , while looking the same on the outside are much different on the inside. Example: Two remotes in a household with 2 decoders in different rooms. To eliminate one from interfering with the other, each remote is matched to its decoder.
My guess is the problem either lies in the wiring between the decoder and the fuel solenoid ,the solenoid itself or the decoder. I would start by checking the connection blocks under the decode then do a safe continuity test from the said plug to just infront of the fuel solenoid, with the decoder and solenoid disconnected. You can't test the fuel solenoid wiring without an osiliscope??? Or the right diagnostic tool, a trusted Renault electrical engineer has the right kit to test though. You could try taking the solenoid out and visually testing it or taking or sending it to a Renault specialist? I don't joy the price of one, so it night be cheaper to just replace it anyway? It's not an easy job though for the uninitiated! If all that doesn't solve it then it's the decoder box I would reckon with that immo configutheration, on constant! If you need a decoder then if you don't want a heavy bill then it's a trip to the scrap yard for two keys, ring, door lock, decoder, brain and barrel! The other route is pay the Renault guys to run a diagnostic service only. I hope this helps you still? Different configurations of unusual immo light are tell tales to different faults and not the same on different renaults! Sorry mate if you were expecting an easy fix. Pete.
It is called buffering. The video's tend to play and stops at some point and then continue playing because it is still loading the video. Just wait for the video to load completely before playing. You will notice this thru the red indication bar align with the play button. If the loading does not finish, try reloading the webpage by pressing F5.
check for the decoding format selected and the software played. easiest way is to select dolby prologic 2 or similar decoding formats. maximum possibilities to solve your issue. If still no success, check for connections and continuity of center speaker.
OK, so with more troubleshooting, I was able to eliminate the problem with my DE925. It was actually the Vizio HDTV that was causing the problem, as I decided to route the optical audio from my DVD and PS3 directly to the same TOSLINK port on the DE925 and auto-decode worked. It was not the fiber-op cables either. This HDTV was a less-expensive 720p 32" model anyway, so I am not too concerned with the optical out working on it as I can run up to four TOSLINK connections in to the receiver.
you have a picture upside down if u turned a picture on ur computer put memory card in computer and turn picture how u took it decode error will go away
This television has an extremely weak tuner. It is very sensitive to both ghosting (multipath) and weak signal conditions, which cause it's digital decoder to "error out". Coupled with this is the decoder's long set-up time (time to actually begin a decoded video stream after signal is selected)and you find that every time the decoder loses sync it takes several seconds to reestablish normal decoding. The net result is the possiblity that the tuner will be continually restarting and never display anything. An extremely directional antenna may help. Otherwise, find a good external tuner box and use that.
