Take any paper out of the paper feeder and get a plastic ruler the softer the better lift the top of the printer up so you can see where the print cartridges are now push the ruler down through the paper feed roller be careful because you could break the rollers go from left to right right to left twice and check for any debris once you have done this unplug the printer for about 20 seconds then plug back in and let it reset then try copying or printing a doc and see how you go!
SOURCE: hp 2015dn paper jam light on solid,won;t print
There is a manual paper release on the bottom of the paper tray. If it gets stuck the paper does not rise to be picked up. Not sure why it registers an amber paper jam for it, but I taped my release open and put the tray back in carefully. Its been working for 2 days straight now.
My real issue was I had both the low toner and paper jam lights on solid and amber. I waited a few days to post this to make sure it worked. Worth a shot for you all. post back if it works for you .
-T
SOURCE: says paper jam but there is none. pixma mp450
SOURCE: EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Testimonial: "Thankyou"
When the toner cartridge is near the end of its life:
White streaks or light printing occurs.
The LED blinks red.
If a paper jam occurs, the LED on the control panel lights orange. Find and remove the jammed paper.
To resume printing after clearing paper jams, you must open and close the front cover.
