Have you removed the bobbin case to clean it? If so, it probably needs to be reseated. Remove the bobbin. Take out the case and reinsert it. If you can't get the bobbin out easily, there is probably thread clotted up somewhere under the feed dogs. I usually gently rock the handwheel back and forth as I brush the bobbin case area to begin dislodging the "clot." It also helps to remove the throat plate so you have a better view of the mechanics under the feed dogs. You'd be surprised at all the goop that can be caught but you can't see. If you do find a thread clot, use a machine brush and tweezer to gently remove each thread bit. I really hope this helps you. If it does, please come back to Fixya and rate my advice. Thanks!
