SOURCE: my rca rd2762b lyra
I think you have to reintall the software or is your skip button stuck? also this happens when you get water in it.
SOURCE: Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
SOURCE: Problem with My SanDisk Sansa m230
When you delete files on the sandisk it just moves them to an invisable folder labeled .trash inorder to free up some space you need to delete the files inside this invisable folder. if you are using windows then plug in the device and open it. go into you folder options and make sure it has show hidden files selected. If you are using a linux os then go into your view menu and select show hidden files. this should make the .trash folder appear. hope this helps.
SOURCE: profiling requires 4mb free space
Found a small pinhole on the back of the device. In small lettering it says reset. Carefully insert a pin and light push when you feel it's hit a dead end. It resets the issue and you can resume using your device. Leave it up to a girl to find that and figure it out. lol
