Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
Posted on Aug 01, 2011
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
airconditioning
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Mar 05, 2014
airconditioning
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
96171
Points
56
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Apr 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
13117
Points
9
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Nov 26, 2008
SOURCE: Mitsubishi Mr Slim air conditioner
get model and serial #s and look up unit for diagnostic codes
Anonymous
  • 958 Answers
  • Posted on Sep 13, 2008
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Anonymous
  • Posted on Sep 28, 2009
SOURCE: Mitsubishi Mr slim Airconditioner error check P8
I Have same problem
Anonymous
  • 1420 Answers
  • Posted on Nov 13, 2007
SOURCE: no heating from Mr slim
Go to www.mrslim.com. In the Customer Resourses file select library. Select what you want for a guide. I suggest the Operation or Technical manuals. Then select Mr. Slim Spli-ductless. Select M-series Multi-Split and the current. You will need the model number off of the outside unit to be able to pull up info on it. It may be a good idea to get the model number off of the ceiling cassette as well. Research what a P8 and E0 code is.
Typically it may mean low refrigerant or a power problem.
Anonymous
  • 34 Answers
  • Posted on Dec 02, 2008
SOURCE: i need a user manual
we have them, what's the model number you need
1helpful
14times blinking error on mitsubishi electric mr slim
14 flashes is a fault code. You need to determine which light is flashing and look at an online Mitsubishi fault code analysis chart for your model. The light(s) that flash determine the fault. Power, defrost, timer light flash all mean something different.
2helpful
2answers
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Fan won't work on heat mode
the fan has a circuit that faults with error E6 because the circuit is looking for outside condensor unit. I would like to run the fan as a stand alone.
We have a Mitsubishi Mr Slim air conditioning unit, i've checked the circuit breaker, the remote works but the unit will not engage.
DOES IT DO ANYTHING I THINK ON THE RIGHT SIDE IF YOU HAVE YOU BOOK IT FLASHES ERROR CODES IF YOU HAVE THE COVER OFF
Mitsubishi mr. slim showing P8 on thermostat
p8 means problem at out door unit google mr. slim p8 fult code describes in more detail
Jan 15, 2010 • Humidifiers
3answers
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
2helpful
2answers
42helpful
2answers
Getting an E6 error code mrslim
could someone please tell me what an e6 error code on a Mr. Slim mini split means?
Top Mitsubishi Heating & Cooling Experts
 Mikey
Mikey
vince
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
