SOURCE: scratchy mic noice
try to reduce sensitivity of your mic if you can or simply reduce lever of recording which at the same time should reduce sensitivity. ..or get yourself one of cheap logitech mics and record through them
hope this helps
peace
SOURCE: My Toshiba laptop has the built-in Realtek
you have to goto your control panel click start button at the taskbar of your PC then click control panel you will see settings, hardware for your PC locate the REALTEK HD SOUND EFFECT MANAGER...after that now youre in the settings for your audio click the microphone button there you'll see its muted or no voll at all uncheck it the silde to its higher vol for your mic and thats it...your mic is already unmuted
SOURCE: Do toshiba satellites c655 have a built in mic?
The Toshiba Satellite C655 does not have a built in microphone, but it does have a mono microphone jack.
The following website has microphones that are compatible with the microphone jack.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007675%20600011221&IsNodeId=1&name=3.5mm
You may verify at Toshiba's C655 website. It says "No Webcam and microphone built into LCD bezel".
http://us.toshiba.com/computers/laptops/satellite/C650/C655-S5049
Compared with the L670. It says "Webcam and microphone built into LCD bezel".
http://us.toshiba.com/computers/laptops/satellite-pro/L670/L670-EZ1710
I hope this answers your question.
Sincerely,
Nathan Hicks
