Question about Cisco Catalyst 3550-24 EMI Networking Switch
Flashing Lights on Cisco Catalyst series 3550
Posted by rsmeasho on
  • Ap12
    Ap12 Dec 07, 2013
    Hi rsmeasho, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
1 Related Answer
Anonymous
SOURCE: I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Posted on Mar 24, 2009
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Cisco Catalyst 2960-S VS 2960-X Series Switches?
2960-X is manual configurable and 2960-S is smart dont need to configure.
Apr 10, 2014 | Computers & Internet
How to replace power supply for cisco 3550-24 switch
Hi'' as you have purchase a new one, uncover side of your unit then try to learn and have a diagram by copying in each where the all wires go '' or take a photo of it,''' thanks
Sep 01, 2012 | Cisco Catalyst 3550 Ws-c3550-24pwr-smi 24...
Hi Dear, My Name is sajid. I am facing problem in catalyst 3550 switch. in which ports already kept going up/down continously
Can you post the contents of your running config to this post?
Telnet into your switch, and use the command show run - copy and paste the output
Jan 21, 2011 | Cisco Catalyst 3550-24 24-Port Ethernet...
HAVE 24 PORT CISCO CATALYST 2960 SERIES SI ,HOW TO PUT IT BACK TO FACTORY SETING SO I CAN USE ALL 24 PORTS WITHOUT MANAGE..???
Due to the length of the solution I have provided you with a link to the Cisco site on how to reset catalyst switches.
It is not a simple process and you need to read the instructions carefully.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Dec 15, 2010 | Compaq Cisco Catalyst 296024S switch 24...
''!!! WARNING: The switch is not usable !!!''
Not enough info on this problem but you could always check the IOS version and upgrade it although the Cisco 3550 is end of life.
Apr 06, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Open Questions:
Cisco Catalyst 3550-24 EMI Networking Switch Logo
166 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
