Hi fathy eldin,
For more information on the Philips GoGear SA6045, like FAQ's, software, manuals and more, visit http://ow.ly/5R5Ud.
There is an FAQ on PC Recognition @ http://ow.ly/5R5YV, but I would consider performing a Repair/Recovery, which oftentimes resolves these types of issues and also updates the firmware in the process.
Try doing a soft reset first.
Note: Your songs and data will not be lost or corrupted by a soft reset.
If soft reset does not work, then you may have to use the Device Manager to REPAIR/RECOVER your player:
Once the Player is disconnected from the computer, the display will show "Firmware Upgrading" for a couple of seconds and then start up as usual.
Tip: Update your player's firmware to the latest version to reduce the chance of future hang-ups. See "How do I update my player with the latest firmware?" for instructions.
If you have any additional questions or issues, Consumer Care can be reached at 1-888-744-5477.
Hope this helps! If so, please let me know by rating this solution so that I can help others more effectively!
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
