Question about Frigidaire FRA256ST2 WallWindow Air Conditioner
Less than a week ago we installed our Frigidaire FRA256ST2 25000 BTU ThruWallWindow Air Conditioner This morning it beeped and then shut off. NOTHING on the control panel will work but the green light is on on the cord I have checked the breaker, checked the filter, clicked the test and reset button on the cord, tried the controls and the remote controller but nothing will make it come back on.... Any suggestions?
Posted by shearrersara on
mpcheesman1
    Genius:
  • 1,400 Answers
Hello
The control panel sensor is bad.I would take the unit back asap.There should be a 1 year warranty on the unit.
Posted on Aug 01, 2011
Need new control board-shorted out. Can I replace? How much?
For what type appliance. Most control boards are replaceable except some jenn aire models
I’m happy to help further over the phone at https://www.6ya.com/expert/david_66a56a0239b6ab32
Jul 28, 2015 | Amana PTC123B35AJ 12000 BTU ThruWallWindow...
Manual Available? BTU rating
Good Morning Friend,
I understand you are looking for the manual to your Frigidaire air conditioner, model# FAC084N7A. I also see you want to know the BTU rating. Your air conditioner is rated 800-BTU. I have attached the manual below. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Jul 09, 2014 | Frigidaire FAC084N7A Air Conditioner
Bought the Frigidaire 6000 BTU Window Room Air Conditioner LRA067AT7 6 months ago and it worked fine until last week, It will not turn on although plugged in and the wall outlet is good. Is there an auto...
Good Morning Luca,
I understand your Frigidaire air conditioner, model# LRA067AT7, will not turn on. I also see that the wall outlet is good, so you are wondering if there is an automatic shut off if the filter has not been cleaned. Your air conditioner does not have an automatic shut off, if the filter has not been cleaned. Please start by cleaning the filter. You can do this easily with the following instructions:
The air filter should be checked at least once a month to see if cleaning is necessary. Trapped particles in the filter can build up and cause an accumulation of frost on the cooling coils.
    1)Push the vent handle to the Vent Closed position (where applicable).
    2)Open the front panel.
    3)Grasp the filter by the center and pull up and out.
    4)Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing
    5)Or instead of washing, you may vacuum the filter clean.
    Also, be sure your air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. Do not run your air conditioner without outside protective cover in place. This could result in mechanical damage within your air conditioner. Do not use an extension cord or an adapter plug.
    The power supply cord contains a current device that senses damage to the power cord. To test
    your power supply cord do the following:
      1)Plug in your Air Conditioner.
      2)The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
      3)Press the RESET button. Again you will notice a click as the button engages.
      4)The power supply cord is now supplying electricity to the unit. 4)
      I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
      -Best Regards-
      WP
Jul 09, 2014 | Frigidaire 6000 BTU Window Room Air...
Why incessant beeping?
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FRA124HT2, begins with a constant beeping, and changes the modes itself, about every 30 minutes. I also see that it ends up on a different setting each time it does this. I suggest resetting your air conditioning, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Bring power back to it and turn it on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRA124HT2 12000 BTU...
Blows warm air
low on freon or compressor not running.
Oct 04, 2013 | Friedrich CP10F10 10000 BTU ThruWallWindow...
How to stop my Frigidaire 15,100 BTU from beeping
Hello Naomi - Thank you for your question. When the air conditioner is beeping, it may be a warning sign that the filter needs to be clean or that you need to reset the unit. The LED (light) will illuminate and beep after 250 hours of operation. After cleaning the filter, you may reset the "FILTER RESET" option by simply pressing and holding down the button for approximately twenty seconds and the light/beeping will go off. However, if you have done this, try pressing the "RESET" button on the GFI plug of the unit. Wait approximately 2-3 minutes and then turn on the air conditioner. If issue persists, then at this point I would suggest reaching out to the manufacturer directly to see if you have any limited warranty on the appliance or you may alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area.
Jun 14, 2013 | Frigidaire 15,100 BTU Heavy Duty Window...
Brand new (3 weeks old) 14K btu Frigidaire blows cold on and off. Serviceman came out (when it was working) and found nothing wrong. Are they just junk or what?
No sometimes the problem is intermint if it just three weeks old take it back for a new one. Dont wast your time for a service call, its cheaper ti repace.
Jul 17, 2010 | Frigidaire FAH146R2T 14,000 BTU...
Air conditioner keeps beeping when on
My little Frigidaire (5 or 6k btu) beeps intermittently and is really annoying. I never know whenn it's going to happen.
Aug 13, 2008 | Frigidaire FAC084N7A Air Conditioner
Frigidaire FRA256ST2 WallWindow Air Conditioner Logo
314 people viewed this question
Top Frigidaire Heating & Cooling Experts
Mike
Harjeet s. bola
Harjeet s. bola
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
