SOURCE: bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
SOURCE: instructions for bissell 9200E carpet cleaner
ou can find the manual for this vacuum by clicking on the following link: http://www.bissell.com/images/UserGuides/9200_908.pdf
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
SOURCE: have a bissell powerwash proheat carpet cleaner
Go to the following site and enter the product name or model number:
http://www.bissell.com/user-guides/
