Question about Toshiba Satellite Pro 490CDT Notebook
To Whom It May Concerned Dear Sir/Mdm I've a Toshiba Saterllite Pro 490 cdt/4.0 system unit - model no. PA1269E LXCD - Serial no. 68013859. Now it's malfunctioned. Used to have the hard disk partitioned with Windows 2000 on it. I reinstalled with Windows XP Pro but realised it had insufficient disk space on my hdd of 4GB after Windows Updated, so I decided to delete it with KillDiskSuiteFree's Active @ KillDisk for Windows. But then "Error Loading Operating System" appeared after system rebooted. Since then I'm unable to access anything on the system; not even from the CDD nor the USB. Can you upload the Toshiba Companion Diskette in CD form cause my diskettes already misplaced, and floppy drive not working since then. Or maybe a wiser advise would greatly be appreciated. Thanks in advanced
Posted by Gh05t2F1x on
5 Related Answers
Jose Ramirez
  • 263 Answers
SOURCE: Toshiba A60, Won't Load Windows XP.
did you try with diferent memory ram may be that is your problem because the memory can not prosses all the data to download windows
Posted on Jan 01, 2008
Anonymous
  • 56 Answers
SOURCE: Stop 0x0000007B
I belive it ot be the issue with the drive as the other one is working fine.However you can check this for what else you can try...http://support.microsoft.com/kb/324103
Posted on Jan 03, 2008
Anonymous
  • 432 Answers
SOURCE: error 0200 fixed diskette error
Your hard drive crashed. They're fairly easy to replace. Ebay has great deals on 40 and 60 gb hard drives.
Posted on Feb 14, 2008
Anonymous
  • 94 Answers
SOURCE: Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Posted on Aug 11, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Toshiba Satelite A65-S1762 hard drive problem
That means that the disk has a bad sector.
Try chosing the option to format the hard drive during the system installation.
If that does not work, then replace the hard drive.
Posted on Nov 16, 2008
Hello I have the Satellite Pro CDT. But after I turn in On gives me the : Insert System disk in drive. Press any key when ready.... What i have to do ? Do I need a System recovery disk original ? I...
try to tape msconfig in Run , then uncheck all programs from Start. if dosent help then you should get your system cd because you one system file or more
1helpful
I want to know the serial number of Corel Paint Shop Pro Photo X2. Thanks in advance
Hello and Welcome to FixYa!
Sir/Ma'am if you have misplaced your Key, in case you have bought the Software then you can provide the Vendor's a proof of purchase and they will give you your Key in return.
But IF you are searching for a free key/serial/crack this isn't the right place, as FixYa strongly prohibit such type of activities and keep a record of its customers and experts along with their IP's to avoid any miss use.
I hope you understand.
Concerned, Nooh
What is the drive type used in the Toshiba 2415 S205 laptop?
Specifications of TOSHIBA Satellite? 2415 Series
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Home
Satellite 2415-S206
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Pro
Performance
Mobile Intel® Pentium® 4 processor-M at 2.00GHz
Memmory 256MB expandable to 1024MB
All-in-one design
40GB* hard disk drive
DVD-ROM/CDRW multi-function drive
I have a used Toshiba 480 CDT laptop computer and
Try this link first however I think it's more of a spec sheet.
http://germain.its.maine.edu/~hiebeler/480cdtmanualpages.pdf
Some help with memory upgrades
http://germain.its.maine.edu/~hiebeler/480cdtmemory.pdf
And more details specific to your model here
http://germain.its.maine.edu/~hiebeler/480cdt.html
Hope these help
Marc
Only get 3/4 display screen on monitor
Your post is not very clear on the exact problem you are having. If your issue is that some web pages have large amounts of blank white space to the right or both left and right of the web page, then the issue is you have a high resolution LCD and the web page was written using page frames. (If this is the case, the web page is being displayed as designed and there is no fault to the system)
If that is not the issue, then post specific details as to what you are seeing and what you are doing when the issue occurs.
Toshiba Satellite Pro 490CDT Notebook Logo
Top Toshiba Computers & Internet Experts
Ekse
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
