Question about Zebra LP 2844 Thermal Printer
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How can I use DOS command to print text to the printer via USB port?
Posted by mark_jiang on
pkwc
    Champion:
  • 254 Answers
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Posted on Aug 12, 2011
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Zud - print error - under temperature
Try using the latest zebra printer driver. The ZUD driver has been superceded by the latest Zdesigner driver which works in Zebra Designer and any windows application
Jun 09, 2009 | Zebra LP 2844 Thermal Printer
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Printer Clicking
What kind of printing job are you trying to do?
Jun 11, 2008 | Zebra LP 2844 Thermal Printer
NEED THE DRIVERS FOR MODEL NO LP2844 ZEBRA
I have found that some times the zebra driver don't work well with Xp or Vista. Try these drivers :
http://www.seagullscientific.com/aspx/thermal_95.aspx
They have never let me down.
Dec 22, 2007 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
524 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
