Normally a good indication would be that when the compressor tries to kick on, it gives a "moaning" like sound, power draws down and normally will trip the circuit breaker in panel. Yes it can be changed "very carefully" , as they are a dangerous source of electrical shock. Have to remove cover on roof, and you'll find small metal cover to remove to expose the capacitors etc. Look for burned wires as well.
Handle all wires etc, with insulated pliers ( needlenose ) and don't touch terminals on top of capacitors with anything else but insulated pliers, and never touch a screwdriver or any other tool across those terminals when your in there.
The capacitor with brown wires is for fan, other 2 are compressor start, and compressor run.
You can check with a multimeter that has a micro Farad checker you can read on the cap what the mF is and what the range will be plus or minus a certain percent. You can change it just remember how you took the wires off. example 80mf cap plus or minus 10 percent would be72-80 would be good cap.
