Question about Amana 26 cu. ft. Side-By-Side Refrigerator, ASD2622HR
Have an Amana Refrigerator side xside. 26cu ft. Model ASD2620HRW I put a new water filter in and it made a banging type sound. When dispenser is pushed,makes the banging sound for a little bit, and water comes out very,very slowly. When the filter is takin back out, it is leaking from the connection unit? Please advise, repairs needed. Thank you, Jeff
Posted by matfam40 on
Michelle Balcom
    New Friend:
  • 87 Answers
Make sure your part is original manufacturer, check that o ring wasn't left from old one. Your new one is not seating properly.
Posted on Oct 02, 2017
michael Rettig
    New Friend:
  • 5 Answers
Make sure there is nothing blocking the dispenser, like build up ice
5 Related Answers
MARK FISHER
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
David Coomer
  • 1073 Answers
SOURCE: AMANA SIDE BY SIDE
what is the model?
Posted on Apr 17, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Posted on Nov 16, 2008
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: My Amana Refrigerator Freezer Model
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 27, 2010
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
SOURCE: my amana refrigerator model number ASD2620HRR,
42434
Sorry to hear about your problem.
Your main control card is defective. and or your compressor is causing the card to fail, or the card is trying to start the compressor.
You will need to call a service company to resolve your issue.
Since I tried to help you, please help me and rate/vote this response. Thanks and good luck.
If you live in the Denver,Co area I can help you.
Posted on Dec 23, 2010
Tfx25zr where is water filter
If your model has a filter The water filter cartridge is located in the
upper right-hand corner of the fresh food
compartment, right below the temperature
controls.
The filter cartridge should be replaced
every
six months or earlier if the flow of
water to the water dispenser or icemaker
decreases.
Download User Manuals HERE
Sea Breeze
Older Model
TFX25ZRY
Use and Care Manual for above model(s)
TFX25ZRBAA
Series 25.2 Cu. Ft. Side-By-Side Refrigerator with Dispenser
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBWW
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBBB
Quick Specs
Use and Care Manual
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
My amana refrigerator model number ASD2620HRR, 26cu ft is making a buzzing noise and has stop getting cold
42434
Dec 23, 2010 | Amana ASD2522WEB (25.1 cu. ft.) Side by...
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Slow water flow from water dispenser
Check water supply make sure you have ample water and not a kinked connection from supply. It is a common failure on Amana to have a defective Filter/Head assembly.
Mar 28, 2010 | Amana 22.6 cu. ft. Side-By-Side...
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Filter change
Nov 10, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Sep 05, 2007 | Amana ASD2326HE Side by Side Refrigerator
Amana 26 cu. ft. Side-By-Side Refrigerator, ASD2622HR Logo
41 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
