LG LP1200DXR Portable Air Conditioner Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Only warm air blows out of the vent. Not cooling. ??
Anonymous
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Jul 31, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
10988
Points
226
2004 Tahoe ac only blows cold from drivers vent. Passenger and back seat blows hot.
https://www.youtube.com/watch?v=mS56WnGUSTU
https://www.youtube.com/watch?v=--SCk_gHM4o
This problem is a low freon charge in the system. ... But a system that is 1/2 pound low will cause the passenger side vents to blow cool or cold air, and the drivers side to be less cool or even warm on this car. There is simply not enough freon capacity in the system to cool the air to the drivers side. https://www.justautorepair.com/buick/century/cool-passenger-warm-driver
Driver side blowing warm air with ac on , passenger side cold...2007 Impala
The 2 vents on the drivers side have warm air blowing out. ... But a system that is 1/2 pound low will cause the passenger side vents to blow cool or cold air, and the drivers side to be less cool or even warm on this car. There is simply not enough freon capacity in the system to cool the air to the drivers side.
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Air conditioning not blowing cold
may have air trapped in it still or thermostat is not working properly..
2002 eclipse heater blows cool air
Check your antifreeze level and if low then add antifreeze until the radiator is full and the overflow tank is up to the correct level. that should solve your problem. If it isn't that, chances are your thermostat could be stuck open which isn't allowing the coolant to warm up properly.
Good Luck
1helpful
WHAT IS WRONG WITH THE AIR CONDITIONER IF THE 2 RIGHT VENTS BLOW COLD AIR BUT THE LEFT VENTS BLOW THE CIRCULATED VENT AIR (WARM)
By my experience you have a low charge, it sounds nuts, but for some reason it will blow warm on pass side and cool on driver side with low charge.
If the charge is correct, than you have a actuator issue.
It will have to be looked at for proper diagnosis.
I would start with a a/c performance test.
Air con faulty, warm air when LO selected
you have a bad blend door or just stuck
1helpful
Bryant Legacy Line air conditioning not blowing cool air..
Your outdoor condenser is in heat mode. Check the wires on the thermostat. Sounds like a small wiring problem and nothing else. Good luck. Please keep me posted as to you progress.
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
