Question about Maytag EPIC MFW9700S Front Load Washer
Control lock light is on and nothing else will respond, and this continues even after unplugging/replugging. help!
Posted by catecarr on
Kevin White
  • Maytag Master
  • 1,902 Answers
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Posted on Aug 01, 2011
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
X6150 printer worked fine until I was running out of ink. So replaced both 82 and 83 cartridges (new). Then got online help with 50C error message; moistened gold area on both surfaces of cartridges and...
Try to do the Clean Cartridge function using the control panel on your printer. 1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
If problem continues and it's beyond return period, please contact Lexmark technical support for additional assistance.
Source: Lexmark X6100 Series User's Guide
May 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
The machine's "Control Locked" light is on.
Did you try to push and hold the 'CYCLE END SIGNAL' button for 3 seconds?
May 02, 2010 | KitchenAid KHWS02R Front Load Washer
Not working
It sounds like 2 separate problems:
1) One of the cooktop lights may have shorted. Sometimes this happens and causes damage (repairable) to the control circuit board. Sometimes it will result in the lights or fan not working, or not turning on.
2) You may have a bad magnetron. See this FixYa solution.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Apr 27, 2010 | GE Microwave Ovens
The program light won't stop blinking
Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Locked up
unfortunatley...its toast! time to throw it away and get a new one.....im guessing a surge has possibly cause major damage to the main CPU of the unit ive seen this with home appliances all the time....hope this helps,ben
Aug 11, 2009 | Televison & Video
Control locked light is on.
The procedure for clearing this is to press and hold the "end of cycle" button for three seconds. It should be all the way on the right of the panel. Let's try this first. before we look at anything else. Hope this helps and let me know what happened. Good luck.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore 4eHT Frontload Washer. It is about 2 years old. The washing maching won't start. The light that says control locked is on. Basically, it doesn't respond when I try to start a cycle. ...
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is a designed safety feature that prevents small children from manipulating the front panel controls. Sometimes the control panel can become inadvertently locked. If these preliminary steps do not solve your problem, please post back and let me know. I hope this helps you.
Jul 07, 2009 | Washing Machines
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Maytag EPIC MFW9700S Front Load Washer Logo
131 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
