Question about Cooktops
My glass Whirlpool cooktop cracked. Do I need to buy a whole new cooktop?
Posted by jrdunc252 on
Gene Meier
  • 2,341 Answers
No just the glass could be ordered seperatly, the cost of the glass could be as much as $300 for just the glass and unless you plan to replace it yourself it could cost $175 labor for the repair tech to transfer all the parts from old to new glass. So what would be more financially better,to spend up to $500 to repair of 7-900 to replace
Posted on Jul 31, 2011
I have a crack in the glass top cook top across the left front cook area. And this be fixed?
Hi glors732,m
A chip perhaps, but not a crack, you will need to replace the whole glass panel. Will be quite expensive though.
Kind Regards
JEDMEYER1
* If this solution helped you, please rate it.
Aug 08, 2011 | GE 30 in. JP340 Electric Cooktop
I have whirlpool glass cooktop{white}this is the second that has been installied and has crack and stains very easy cant wasting money on cooktops. If another one has to be installied it will be a total of...
It might be worth your time to contact whirlpool and complain, you might get a new part out of it. However they will probably want it serviced by a authorized servicer....
Assuming your using the cleaner, correct pans, not using a big canning unit, and unit is level with no uneven floor under it, your having bad luck..........
Whirlpool does make a distinction between impact cracks, and flaws and internal cracks on the cracks in glass tops.........(if something was dropped it leaves a different type of crack or cracks than a flaw)
Think your best bet is to call company customer assistance to see if they are willing to do anything, good luck......
Mar 01, 2010 | Cooktops
Cracked glass top stove. is it covered under a waranty? it is maybe 4 years old. brought at sears its a whirlpool stove.
whirlpool offers a five year warranty on glass cooktops for thermal damage only not for customer mishaps so call a certified repair place and they can get you a new cooktop if you tell them that it is thermal cracking
Sep 12, 2009 | Cooktops
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Burner out in whirpool black glass cooktop
take the whole cooktop out there should be screws around the base you take them out, seperate the bottom from the glass you should be able to get to the element to check if it is bad by ohming it out
May 01, 2009 | Cooktops
I HAVE A WHIRLPOOL ELECTRIC COOKTOP WITH A LARGE CRACK CAN I REPLACE JUST THE SURFACE IF SO WHERE CAN I GET ONE?
The glass can be replaced. Go to any appliance parts website and look up the model number for your cooktop. They should have a parts directory and then search for your cooktop glass. I warn you though - the glass is almost as expensive as a new unit!!
Mar 13, 2009 | Whirlpool GJC3034 Electric Cooktop
Ceramic glass stove is cracked
HI
You should be able to replace the top only.
Normally if this is your fault, it is not covered by warranty. Normally this would be if you dropped something onto it. This would leave like a star shap series of cracks.
If its down to manufacture, this should be covered under warranty. This damage normally looks like just one long crack, no impact mark.
Check with the manufacturer
Rob
Feb 18, 2009 | Cooktops
Cooktops Logo
892 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
