Vivitar (1607225) Telescope Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Put it together, have the lens in but yet it is black. The cover on the front is off and still black whenever looking through the lens on the side. HELP
Joe Lalumia aka TelescopeMan
Level 3:
  • Master 3,186 Answers
  • Posted on Jul 31, 2011
Master
Level 3:
Answers
3186
Questions
Helped
951843
Points
7111
This sounds like a reflector style scope with mirrors-
Put the eyepiece with the largest number written on it into the focuser--- do NOT use the 2 x barlow if you have one. Take the scope outside during the day time and practice focusing on a distant object. The end with the focuser on the side is the UP END of the telescope.
We see many beginners with these types of scopes mounted backwards pointing at the ground.
Black verticle lines on our optoma EP1691
I just fixed mine at no cost! This problem is definitely with the DMD chip, but it may not need to be replaced. Try this first: 1. Carefully remove the lamp. 2. Remove the three screws from the bottom and the 3 black screws from in front of the housing near the lamp vents. 3. carefully remove the cover and using a spudger lift up on the black clamp lever holding I the ribbon cable to the system board. Set aside the cover. 4. When looking at the projector from the top with the lens facing away from you. The DMR chip board attaches to the main board on the left hand side of the main board just behind the lens. 5. If you press gently on the card edge connection on then main board for the DMR chip board, you may notice some slight movement. 6. Gently tighten the screw that holds down main board nearest the lens and closest to the DMR chip card edge connection. (I tighten all the screws holding in the main board as some of the them were quite loose from years of use.) 7. Put it all back together... When replacing the ribbon cable be careful not to jam it into the slot. Make sure the black clamp is up, and gently slide it in until it clicks a little. Put down the clamp. 8. Once all is back together... try it out. This fixed mine. No more black and white lines. I use my projector for outdoor movie nights mostly and my thought is that the DMR chip board became loose and some corrosion from the moist night air caused a bad connection on one of the card edge traces. Either the action of moving the card edge removed some of the corrosion and made a better connection, or the tightening of the screw caused a better connection. I hope you have the success I did.
6helpful
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
14helpful
2answers
Fitting instuctions for replacing lcd screen on my samsung e250 mobile phone
ok...
1.take off battery cover, remove battery, memory card and sim card
2. remove the five screws on the back... two at the bottom, two in the middle and one on the mid top right and take off this cover, remember! keep the screws safe
3. slide the phone up and take out the two screws on the left and right paralel with the battery tabs then remove the two screws ether side of the camera...they might be covered by rubber coverings, these pop out easily
4.now you can prise the top of the screen off with a small flat headed screwdriver
THERE ARE TWO OPTIONS HERE, IF THE REPLACEMENT SCREEN HAS NO RIBBON CABBLE ATTACHED THEN FOLLOW FROM FIVE, IF IT HAS ONE CONNECTED THEN FOLLOW FROM
5. its conected to a ribbon cable, remove the tape and slide out the cabble from the screen.
6. now take out the screen PCB from the plastic casing and replace it with your new one and put the ribbon cable in and clip it back together, now reverse stages 3 to 1 to put it back together.
7. if the ribbon cable is attached now you must look at the PCB board on the back for a square copper line, on the left of this there is a big black square just smaller than the copper square, prise this off with your finger nails, keeping it to the side take the PCB up about 2mm and then fold the bottom of it to revele it is conected to a ribbon cable by a bigger version of the black square so prise this off and take the PCB and put it safely to one side.
8. look on the front of the phone under the top bit of the screen, there should be a semi circle in the plastic with a black circle in the top of it, use your nail or a flat headed screwdriver to pop it to the other side of the semi circle, now the slider should go past what it used to o you can slide it up to when you can see the ribbon cable go down through the phone, now push the black square end through and you should be able to slide the whole front off.
9. replace the screen by taking the screen PCB out and repacing it, then thread the ribbon cable back through and slide the front on while making sure the back circle goes into the semi circle and to the top side of it, then thread the black square through the phone to the front and clip the phone front back on.
10. snap the black square back on to the back Circuit then put the circuit back into the phone and snap the small black square back on then go from stages 3 to 1 to put it back together.
this should be fairly easy to do for most people.
Jul 03, 2008 • Cell Phones
Canon S2 IS
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
Lens cover stays in between, won't open nor close
Had a similar problem once. Fixed it by opening the camera and freeing up the lens cover.
1)Undo 2 screws each side and the base (6 in all) ignore the one on the front edge of the base for now.
2)Separate the base from the case (gently!) don't pull them too far apart, because they're joined by ribbon cables.
3)Then remove the long screw you ignored above, and again carefully separate the front panel.from the body.
4) At this point, you should be able to access the back of the lens cover, and free up the mechanism.
Once that' s done, put it back together, reversing the above sequence. Don't force anything, just make sure they're all lined up and fit before inserting the screws.
good luck.
Front cover change
hi there
this is the procdure...
First remove the back cover, the battery and the SIM card.
Now remove the top part of the back cover (the part above the camera). Do this by inserting a small flat bladed screwdriver between the white and black parts of the phone, and lever the screwdriver up like a small crowbar on either side of the lens. The black cover should slide up and off the phone.
Looking at the top of the phone, remove the small on/off button and put it in safe place. Also remember to remove the little mirror or rubber grommit from beside the camera lens and put that in the same safe place as the on/off button. Losing these little bits will cause you no end of pain as they are not available as spare parts.
The next bit to remove is a small green plastic bit of circuit board. It's clipped in and sprung against some data pins. Again using the flat bladed screwdriver, pop it off in the direction of the top of the phone.
The whole rear of the phone should now be exposed. Using a T6 torx screwdriver, unscrew the four small screws indicated. Put these screws in that safe place.
Once the screws are out, hold the phone like so, and squeeze gently on the sides and lower edge of the phone case, the pressure should be enough to create a small gap between the fascia and the sides, using a fingernail or thin plastic (like a credit card) make the gap bigger until the fascia pops off. Repeat on the opposite side of the phone if required.
The fascia should now lift off completely, exposing the front of the phone.
Push your replacement fascia on until it clicks into place, and reassemble the phone. if all has gone well, you should have a T310 that looks as nice as the one shown above.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
2answers
How to Remove the Lens Cover on a Sony DSC-T7
It is only six screws, and you have to GENTLY wiggly the front cover off....Start at the bottom, and wiggle side to side to get it unattached at the top of the panel. I just got mine off. I'm having black screen problems....
3helpful
3answers
No power !
As indicated in solution #2 dirt deposits in the channel that prevents the cover from moving the switch to turn on the camera. To get at the channel to clean out the **** remove the 6 small screws (two on each side and two shorter screws on the bottom of the outside of the camera). Remove only the six screws that are holding the front of the camera body on. The silver band seperates the front of the body from the rear. Wiggle off the front of the camera body. With the lense cover closed you can wiggle off the plastic inside of the front cover from the exterior of the body. By doing this you'll expose the track that the lense cover rides in. Notice that the top track moves back to contact a black plastic switch. **** will typically be in the channel preventing the lid from contacting the black switch. Clean it all out and reassemble. Camera should work fine.
2answers
Digital dsc F707 problem
I used Super Glue and my camer ia stil working.  However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
Top Vivitar Optics Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
