the leading thing causing that is a dusty condenser coil. to clean that remove the grill above the refrig, and the white painted plate behind that and vacuum the coil on right side ,typically the grill is held on by springs and a either 1 screw in the center or 2 screws on the corners of the rim above the door,remove grill by opening refrig. door and remove screw tilt grill down and disattact springs
Good luck, i hope this helps
Gene
Testimonial: "We've tried to clean the coils, but will try once again. Thanks, Gene."
