Question about Kodak EasyShare One Digital Camera
When i turn the camara on it makes a loud noise like its trying to open the shutter then it doesnt focus if i zoom in or out.
Posted by blitzy7979 on
Anonymous
    New Friend:
  • 9 Answers
There might be something in the lens. even a grain of sand to do that. try flushing it out with an air sprayer or dust sprayer.
Posted on Jul 31, 2011
Nikon autofocus shows r10 and the autofcus is not working when I zoom in and seems to be making a noise
The "r10" message in the viewfinder is NOT an error code. The "r" stands for "remainder" and the "10" is the value. Together, it tells you how many more photos the camera's built in, high speed memory buffer can hold BEFORE the shutter will be stopped - so that the pictures in this memory can be transferred to the removable memory card. The process will take a few seconds or more - depending on the speed of the memory card you provided in the camera. If you pay attention to the the "r" number, while taking photos is rapid succession, after each picture - the number will decrease by one. When it reaches 0, you can no longer take additional pictures. During this time - the camera is moving the pictures to the memory card. When done, the "r" number will be high again, and the shutter will operate again.
The auto focus motor will make some noise it is turning to advance or retract the focus mechanism, and is normal. The camera requires sufficient contrast to obtain focus. Most of the time, a well lit subject will provide this. If you are zoomed in on a rather featureless subject - such as a clear or overcast sky, solid color flat wall, etc., where there is a lack of contrasting objects in the viewfinder, the camera can not detect an "edge" on any object; so it attempts to focus over the entire range of the lens to find it. If it can't, it prevents the shutter from releasing.
There is also a minimum distance that the lens will focus, too. If you are trying to zoom in on a close object, the lens may not be able to do it. In this case: either back away, zoom out - or both. If you need to get close to objects, you should consider buying "Macro" lenses. Nikon brand lenses that do this type of photography, oddly are called "Micro" lenses instead.
I hope this helps. Good luck!
Oct 09, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
Weird noises when it's on and zoom button noise picked up on vid
change auto focus to single focus mode,
since it is on continuous auto focus on default, it would focus all the time so you don't need to click half way before taking a picture
Mar 22, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
On the lens makes a clicking noise shutter goes in and out turns.
Did you drop it? if you did you have damaged the gear drive motor for it. Are the batteris good?
Jul 06, 2009 | Olympus FE-210 Digital Camera
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Optio M20 Stuck on Zoom in and out!
you have a timing problem,the gears for your housing is out of calibration with your focus lens inside of the housing. you must take the camera apart to correct the problem.there is a flywheel type of ajustment in the top of the camera that can be turned to bring the camera back to its reset position. it is bad to keep turning on the camera as this may danage the gear that is out of time.
Sep 12, 2008 | Pentax Optio M20 Digital Camera
Red light, Won't focus, horrible loud wail noise.
if you love your camara bring it to a olympus dealer and ask them to check what the repair costs would be than uyou can decide to try it your self, buy a new one or let it be fixed.
Sand is always dangerous , it can come to vital parts where you don't want it to be.
cleaning yourself:
especially do not use a vacuum cleaner to suk the sand out, but , use enough light, a pair of steady hands, a box to fit in the screws (make a drawing witch srews where when) and take the time, use inside only a clean painters brush (thin) and wipe out any sand that can be seen, from the optics. than after cleaning assemble it in the reverse order of the disassembly , put all the srews in their place tighten them hand vast (not with a electroic tool but only by light force ) vast is vast (meaning it should use a light force to open the screw) and preferably use a dust free environment (rent a baby's box like in the hospitals used for very young childern)
but my advise would be advise nr 1: bring it back to the dealers
May 17, 2008 | Olympus FE-180 Digital Camera
Camara doesn't take pictures
when a please turn on and off again appears there is normally a fault with or in the lens. I dont like to suggest that the camera must be opened by anyone that is not qualified to do the repairs because these cameras have components in that could be damaged and will only make the problem worse.
Jan 01, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Out of focus
Sounds like the camera is trying to focus if you hear sound when pressing the shutter halfway down or zooming. If the noise is a scraping or grinding sound, you might have debris stuck between the cracks of the lens and the camera body. This happened to me after i dropped my canon sd550 on the beach just once and it never recovered. Next to water sand has got to be one of a camera's worse enemy. Also, the lens might be cocked a bit which would prevent the camera from focusing and zooming smoothly. Try gently adjusting the the lens. Sometimes the slightest imperfection in the lens will throw everything off. Good luck!
Apr 11, 2007 | Kodak EasyShare Z760 Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Kodak EasyShare One Digital Camera Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
