Computers & Internet Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop has changes its theme .. i usually want to turn it back into windows 7. but how?
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Jul 31, 2011
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1405393
Points
12062
Start, type theme in search box, click change theme on the menu, you can select the windows 7 theme there
1helpful
HOW TO DELETE AERO FROM MY WIN 7 HOME
Windows Aero Glass is Microsoft's 3-D high-end interface for Windows 7. In order to get this interface, you must be running a video card that supports running Aero Glass. Some video cards barely support running Aero Glass and performance suffers and the computer will lag. By simply disabling Aero Glass, you can take a crawling computer and bring new life into it. In any situation, if you want to increase performance, disable Aero Glass.
Right-click on the desktop and select Personalize. Select Windows 7 Basic theme and a "Please Wait" icon appears and changes your theme. Select Windows Classic theme if you are used to a Windows XP look and feel. A "Please Wait" icon appears and changes your theme. http://social.technet.microsoft.com/Forums/en-US/w7itproui/thread/ce96731f-8f7a-4d13-ba9b-7826cb595e3d
The text on my pc keeps going blue, how can I stop it?
Windows allows you to change the themes of your computer. This includes the wallpaper, the screensaver when your computer is idle, any noises it makes, and even the color of the toolbars and windows. Sometimes, however, when you restart your computer, the theme will revert back to the Windows default theme, which is called Aero. This can be because you have not disabled Aero, because your performance settings are using too much energy, or because your screen resolution is too high or low for the theme you are using.
Screen Resolution b> The higher your screen resolution, the sharper the images and text will appear. Sometimes, however, the of the wallpaper for the theme is not the same as the screen resolution. This can cause your theme to revert back to the default. To fix this, click the "Start" button. Then click "Control Panel." In the "Control Panel" window click "Adjust Screen Resolution" under "Appearance and Personalization." Select the resolution that is the same as your wallpaper. b> Performance Settings b> If your computer is running on high performance settings, your computer's energy will be used quickly and Windows may automatically change the screen saver to keep the energy from running to low. To change your performance settings, open the "Control Panel" and click "System and Security." Then click "Change Battery Settings" under "Power Options" and select "Power Saver" or "Balance." b> Disable Aero b> Aero is the default theme setting for Windows Vista and Windows 7. If you try to change your theme and it reverts back to Aero, it is because Aero is still not disabled. To disable Aero, right-click on your desktop and click "Personalize." A window of all the themes on your computer will open. You will see "My Themes," which are any themes you have created, and "Aero Themes" under it. To disable Aero, click "Save Theme" under "My Themes" to make your current settings default, or select one of the themes under "My Themes." This will make that theme the default. b> Troubleshooter b> If you still cannot figure out why Windows changes the theme back to the default after restarting, you can use Windows's built-in troubleshooter. The troubleshooter will find the source of the problem and automatically fix it for you. To use the troubleshooter for your theme, open the "Control Panel" and click "System and Security." Then click "Troubleshoot Common Problems." Under "Action Center," select "Appearance and Personalization." The troubleshooter will run. When you restart after it completes its action, your theme should stay the same. Hope this helps.
b>
My acer doesn't have the cool windows 7 theme, like when you slide through the taskbar and the icons show a picture of whats going on in the page you're about to open, how do i change it to the...
Hi! Welcome to www.fixya.com.
You can download the taskbar theme from this website: http://www.topshareware.com/taskbar-themes/downloads/1.htm
Just pick your choice.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
3answers
I cant change my desktop background on my acer aspire one happy netbook ive looked at everything i can possible think of and nothing workers. it had windows 7 started preinstalled on it. please help
You can download backrounds from microsoft win 7 websight,
Also try right clicking on your desktop and choose personalize,then choose desktop themes.
2answers
How can i changes laptop themes theres no setting at control panel
Right click anywhere on the desktop screen,you will get a drop down menu.Click "properties"(for win xp) or if its win 7,select the last entry on the list.You will get your theme settings.
Thank You.
WHY CANT I CHANGE THE BACKROUND ON M ACER LAPTOP?!?!?!
Please check if you're using the Windows 7 Started Edition. In Windows 7 started edition, changing the desktop themes and configurations are not allowed.
Thanks for using FixYa.
2answers
How do i change my theme back to default
Here is a link to all the information on how to change themes in windows vista:
http://windows.microsoft.com/en-US/windows-vista/Change-desktop-theme
Thank you and enjoy,
Lee
2helpful
2helpful
2answers
Is their a program i can download to change my themes for windows 7 starter at first i couldnt change my wallpaper but then i found a program called OC and its possible so i wana know if someone created a...
Microsoft windows 7 has default 5 theme but Windows 7 beta 1 build 7000 onwards has several hidden & locked themes provided for regional countries such as Australia, Canada, Great Britain, United States and South Africa.Since these hidden themes are installed along with your Windows 7 installation you can unlock/unhide these hidden Windows 7 Themes for regional contries. Below are three deferent methods to get Windows 7 hidden themes.
Screenshot of Default Windows 7 Themeswindows-7-default-themes.jpg Method 1: Steps to Unlock & Unhide Windows 7 hidden locked Themes1. Unhide the Windows 7 System and Protected Operating System files from Windows explorer -> Organize -> Folder and Search Options -> view tab
2. Navigate to C:WindowsGlobalizationMCT.
3. Open a MCT-(AU, CA, GB, US, or ZA) folder for the regional theme that you want.
NOTE: AU, CA and ZA regions all have the same themes though.
4. Open the Theme folder in the selected region folder.
5. Select the .theme file to use it.
NOTE: Once you select a .theme file, Windows 7 will save it so that you will be able to change or select this theme again from within the normal Personalization window location.
6. Hide the Windows 7 System and Protected Operating System files.
7. Enjoy your new regional themes!!
Method 2: Using windows 7 Search (Simplest Method)1. Go to Windowswinsxs Directory
2. Search for *.theme.
winsxs-themes.jpg3. Double click themes with name in the format of XX to apply and save the theme.
Method 3: Registry Entry1. Open notepad and copy past the following lines
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionThemesInstalledThemesMCT]
“%windir%\Globalization\MCT\MCT-AU\Theme\AU.theme”=””
“%windir%\Globalization\MCT\MCT-CA\Theme\CA.theme”=””
“%windir%\Globalization\MCT\MCT-GB\Theme\GB.theme”=””
“%windir%\Globalization\MCT\MCT-US\Theme\US.theme”=””
“%windir%\Globalization\MCT\MCT-ZA\Theme\ZA.theme”=””
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerWallpapersKnownFoldersWindows WallpapersMergeFolders]
“%windir%\Globalization\MCT\MCT-AU\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-CA\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-GB\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-US\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-ZA\Wallpaper”=””
2. Save file as allregional.reg on desktop.
3. Double click on allregional.reg to add above registry entry.
4. Now you can access all Windows 7 Hidden & Locked Themes via right clicking on desktop and personalize settings.
We have created allregional.reg file for you, Download allregional.reg and run it on your machine and access hidden Windows 7 Themes instantly.
Screenshot of Unlocked – Unhide Windows 7 Hidden Themesunlock-unhide-windows-7-hidden-locked-regional-themes.png
Grand Canyon Tech
Grand Canyon Tech
