Question about LG 47LH40 47 in. LCD HDTV
Our brand new LG TV loses brightness whilst you are watching a programme.
Posted by laura539 on
maxwellspect
    New Friend:
  • 4 Answers
Check to make sure that eco mode is turned off. It will sense the ambient lighting and if it is bright, the TV will be bright so if you are seeing the brightness change...check that setting first.
Posted on Jan 27, 2012
3 Related Answers
Anthony Gonzales
  • 267 Answers
SOURCE: dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Posted on Mar 16, 2009
heeman mohun
  • 1341 Answers
SOURCE: Whilst watching SKy HD programs either HD or
You may be experiencing problems due to signal lost.These are sometimes caused by trees etc and sometimes the dish may need to be moved.
Posted on Dec 08, 2009
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 29, 2009
My t.v. picture goes dark when watching programmes
is it by any changes an LG ? if so its the main av board at fault LG's and some other tv makes have a brightness control that is controlled only by the tv, its to stop light flicker when changing channels and accessing menus. its because the channel change changes screen out put from say 1080i/p to 470 in a split second.
Jun 21, 2017 | Televison & Video
Lcd tv picture
Replace backlight lamps
Jun 03, 2017 | LG Televison & Video
I have lost the codes book to programme my Majestic RM -900 touch screen remote to a LG TV
Codes to check with LG brand TVs are 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156. To get more codes to different other brand remote controls, check this link.
Jan 30, 2013 | Televison & Video
Hi I just bought a LG M2362D tv monitor and somehow the backlight level (feels like the backlight) will change to very dark automatically every 5 or 10 minutes then back on bright again in 1 minute does...
The tv have a long board that called the tv LCD inverter board,this tv LCD inverter board only job are to control and help the all the amount of the tv LCD screen panel backlight brightness for the tv LCD screen panel for light.This long LCD inverter is the causes and the problems.New tv exchange it for another one,not so new take ur tv warrenty repair qickly the tv long LCD inverter board it is the causes an the problems must have to be change.
Sep 13, 2011 | LG M2362D 23 in. LCD TV
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
I have the LG DVD RHT 498H and have it wired up as instructed in the manual, however in watching BBC Live programmes through Satellite dish, we keep losing the picture for about three or four seconds, it...
Recheck wiring,might have bad or lose wires?Unplug the tv and satellite box.Replug it both devices back in about an hour later.Let the tv reset itself.The satellite box to update it software.The problems,should be solved.
Aug 17, 2010 | Televison & Video
Brand new LG plasma stuck on test screens
Resetting the TV
NOTE:
7. Turn on the TV.
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
LG 47LH40 47 in. LCD HDTV Logo
1,241 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
