Ricoh Aficio 450 Copier Logo
Anonymous Posted on Jul 30, 2011
I forgot user name and password of copy system (Printer Nashuatec Aficio dsm651 ) . I can not get into the system settings. How can I remove the user name and password that I forgot? thanks alot
Anonymous
Level 2:
  • Expert 81 Answers
  • Posted on Jul 31, 2011
Anonymous
Expert
Level 2:
Answers
81
Questions
Helped
51651
Points
131
There is 1 of 2 defaults that if not changed should still be there username service with no password or administrator with no password
if those were changed you will need an new NV RAM chip that will reset all your settings and passwords
1helpful
Hello i have printer DSM-622 NASHUATEC im forgot password for printer , how to reset ??? thanks
Hello!
You can take a look in the Address Book. You will find there your user and password.
If you dont know how to see the address book ask your IT.
See you!
Printer Nashuatec Aficio dsm651 I want software
user tools>system settings>admin> address book then select the user and you can scroll down or goto authentication and change the password.
if you cant get into admin try the username administrator with no passowrd or service with no passwrd
2answers
I have a copier / printer Nashuatec Aficio dsm651. Everything works fine but when I print A3 meter marks my one and not two. The person who has it porata explained to me how to get in 'SP MODE machine...
Hi, in order to activate the double count for A3 paper, you have to go into "special" SP mode. The procedure is almost the same as going into regular SP mode, but as you hit "Copy SP" on the touch screen, make sure you are holding down the pound (#) key. Then you should be able to find 5104.
You can only change 5104 once, so one you enable it you won't be able to change it back to counting larger paper as 1 click instead of 2.
How to print or check nashuatec aficio 2205 system information
???? ???? 2205 nashuatec aficio ?????? ???? ????? ???? ????
5helpful
Ricoh Aficio 3228C asks for user name and password
What is the user name and password refering to?
if it is the administrator user name and password try
user name - admin
password -
blank password.
good luck
8helpful
Aficio 1035 web interface user name and password
The Default factory passwords are not what you have listed. They are the following:
User name: administrator
Password: password (or possibly leave blank)
Give that a try.
However, the web interface isn't all that special on this older model anyway. All you need to program are the Ip address, and subnet mask, as there is no scan to email function, and the scanning can only be done via a software, that you won't have, and is getting difficult to find, because it is no longer supported, and just as complicated to configure should you find it ("Scanrouter V2 Lite" is the name ) as opposed to direct scan to folder. By the way this scanning software is NOT Vista compatible should you find it.
If you can't log into the web interface....on the machine, go to "user tools', "system settings", Interface settings", and set your IP address and subnet mask...that's it.
Please rate response :)
Asking user name and password in Ricoh Aficio MP2000 copier
Pull the litium battery off of the printer card and put it back in. That may reset the password unless it wrote it to the hard drive.
8helpful
3answers
I forgot login password for Ricoh Aficio MP2000 copier
Try getting into service mode and see if you can reset the user passwords by turning them off in the settings.
Do you know how to get into service mode?
How do I put a password on Ricoh Aficio 2051 printer?
go in to user tools, system setting, key operator tools or admin. tools. there you can set up password.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
