Question about Integra DTR-8.3 Receiver
My integra dtr 5.6 receiver is not working. The display screen is blank but the power light is on
Posted by lnorkus on
  • 1 more comment
  • lnorkus Jul 30, 2011
    is there a reset function?
    how do I "power cycle" ?
    How do I "power cycle"?
Veril Gillette
    Genius:
  • 1,126 Answers
It sounds like a bad power supply that is nor feed the votage to the display, or the main processor is locked up and to unlock the processor you need to unplug the unit for 40Min, and it will reset back to normal.
Posted on Jul 30, 2011
Eury Satorre
  • 957 Answers
Please try to power cycle your receiver first. If nothing happens, please let me know so that I can help you further.
Electro Med Services
  • Integra Master
  • 6,694 Answers
As you have mensioned it should be power supply problem. You have to check the voltage regulators at it power supply satge. it should need a good electronics servicing skill to find out the exact problem. if you are not experienced in it, then i will prefer you to consult some one more experience in it for such a costly system.
ok
  • Electro Med Services
    Electro Med Services Jul 30, 2011
    hi,
    Its not a reset trouble. Its powersupply have some problem. Better consult nearest intgra servicing center.
    ok
My integra av receiver model no DTR-70.1 amplifier displays but no sound what could be the problem?
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Jul 03, 2018 | Integra Audio Players & Recorders
How to fix Integra 7.8 display is dead
They will be value of 10 ohms or less in the secondary power supply attached to the front assembly
Jul 20, 2014 | Integra Dtr-7.8 Receiver
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to...
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Dec 26, 2010 | Audio Players & Recorders
Turn on receiver and turns off immediately dtr-5
I have the same problem! Could you fix it
Oct 13, 2009 | Integra DTR-5.1 Receiver
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
No output to subwoofer per-amp
you may have to go into the onscreen menu and enable it,that shuld work
May 11, 2009 | Integra DTR-8.3 Receiver
Integra DTR-8.3 Receiver Logo
381 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
